Salta al contenuto principale
Sony Xperia Z3 Dual Headphone Jack Replacement
Cosa ti serve
  1. Sony Xperia Z3 Dual Headphone Jack Replacement, Headphone Jack: passo 1, immagine 1 di 1
    • Power off the phone and remove two SIM card trays before headphone jack replacement.
  2. Sony Xperia Z3 Dual Headphone Jack Replacement: passo 2, immagine 1 di 3 Sony Xperia Z3 Dual Headphone Jack Replacement: passo 2, immagine 2 di 3 Sony Xperia Z3 Dual Headphone Jack Replacement: passo 2, immagine 3 di 3
    • Heat to soften back cover adhesive sticker.
    • Use suction cup to open a gap and insert into the guitar pick.
    • Slide the guitar pick to cut the sticker all around every side.
  3. Sony Xperia Z3 Dual Headphone Jack Replacement: passo 3, immagine 1 di 1
    • Remove back cover.
  4. Sony Xperia Z3 Dual Headphone Jack Replacement: passo 4, immagine 1 di 3 Sony Xperia Z3 Dual Headphone Jack Replacement: passo 4, immagine 2 di 3 Sony Xperia Z3 Dual Headphone Jack Replacement: passo 4, immagine 3 di 3
    • Remove battery easily.
  5. Sony Xperia Z3 Dual Headphone Jack Replacement: passo 5, immagine 1 di 1
    • Twist off two screws by Philips screwdriver at first.
  6. Sony Xperia Z3 Dual Headphone Jack Replacement: passo 6, immagine 1 di 3 Sony Xperia Z3 Dual Headphone Jack Replacement: passo 6, immagine 2 di 3 Sony Xperia Z3 Dual Headphone Jack Replacement: passo 6, immagine 3 di 3
    • Remove three pieces of securing bracket.
  7. Sony Xperia Z3 Dual Headphone Jack Replacement: passo 7, immagine 1 di 3 Sony Xperia Z3 Dual Headphone Jack Replacement: passo 7, immagine 2 di 3 Sony Xperia Z3 Dual Headphone Jack Replacement: passo 7, immagine 3 di 3
    • Release all the connectors connecting with motherboard.
    • Pry it up from left side. Please be careful with some hidden keys, they held the motherboard really tightly.
  8. Sony Xperia Z3 Dual Headphone Jack Replacement: passo 8, immagine 1 di 2 Sony Xperia Z3 Dual Headphone Jack Replacement: passo 8, immagine 2 di 2
    • Remove securing cover beside headphone jack.
  9. Sony Xperia Z3 Dual Headphone Jack Replacement: passo 9, immagine 1 di 3 Sony Xperia Z3 Dual Headphone Jack Replacement: passo 9, immagine 2 di 3 Sony Xperia Z3 Dual Headphone Jack Replacement: passo 9, immagine 3 di 3
    • Remove the flex cover on the headphone jack. It's a part of the assembly and comes with denoise MIC and sensors.
    • Cut the adhesive sticker between headphone jack and midframe.
    • Remove headphone jack finally.
Conclusione
Altre 4 persone hanno completato questa guida.
Sophia
Membro da: 03/25/14
43.810 Reputazione
62 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 7,002
