Introduzione
Sony Xperia Z3 battery is non-removable. When you encountered the problem with battery, it's a little complex to replace.
Panoramica Video
Heat the back cover to soften the adhesive sticker. Use the suction cup to open a gap from top side or bottom side.
  • Heat the back cover to soften the adhesive sticker.
  • Use the suction cup to open a gap from top side or bottom side.
Aggiungi Commento
Insert into the guitar pick and slide to cut the sticker. Remove the back cover. Remove the back cover.
  • Insert into the guitar pick and slide to cut the sticker.
  • Remove the back cover.
In step 5 where it says that there is adhesive on the battery, my adhesive was actually joining the battery to the back plate making this step quite difficult. I had to focus the heat on the backplate right where the battery was and then use a long lever to separate the battery from the back plate.
Seb Carroll - Replica
Release battery flex connector carefully to avoid breaking the pins.
  • Release battery flex connector carefully to avoid breaking the pins.
Aggiungi Commento
Get free that sticker which for fastening the battery.
  • Get free that sticker which for fastening the battery.
Aggiungi Commento
Pry up with a little effort because there is adhesive under the battery though not so strong.
  • Pry up with a little effort because there is adhesive under the battery though not so strong.
Aggiungi Commento
That's Sony Xperia Z3 Dual 3100mAh battery.
  • That's Sony Xperia Z3 Dual 3100mAh battery.
  • When you finished to replace battery and ready to assemble the phone, you need a piece of new back cover adhesive sticker because it's disposable and the old one can't use any more.
Aggiungi Commento
Conclusione
Altre 11 persone hanno completato questa guida.
Sophia
Membro da: 25/03/2014
39.535 Reputazione
107 Guide realizzate
Do you happen to know if the Z3 battery will also fit the Z3v i cant seem to find a replacement specifically for the Z3v
Victor Aguirre - Replica
Just finished this guide thank you!
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 100
Tutti i Tempi: 26,332
