Introduzione
This guide shows you how easy to replace Sony Xperia Z3 back cover. And if the phone waterproof or not depends not only perfect operation but also the good back cover replacement parts.
Panoramica Video
Heat the back cover for about 1 to 2 minutes until you feel the adhesive sticker is soften a lot.
  • Heat the back cover for about 1 to 2 minutes until you feel the adhesive sticker is soften a lot.
Aggiungi Commento
Place the suction cup on top part or bottom part which you think is easy to carry and open a gap.
  • Place the suction cup on top part or bottom part which you think is easy to carry and open a gap.
Aggiungi Commento
Insert guitar pick into the gap and slide to cut the sticker around the back cover.
  • Insert guitar pick into the gap and slide to cut the sticker around the back cover.
Aggiungi Commento
Especially the left side, you'd better handle as the direction we marked or you are likely to break the flex cable on the left bottom corner.
  • Especially the left side, you'd better handle as the direction we marked or you are likely to break the flex cable on the left bottom corner.
Aggiungi Commento
Remove the back cover easily. It comes with camera lens and NFC.
  • Remove the back cover easily. It comes with camera lens and NFC.
  • And you can place your new back cover, press the adhesive sticker and done the replacement.
Can i back the back cover without using new adhesive sticker?
Christia benedictcruz - Replica
Conclusione
Altre 12 persone hanno completato questa guida.
Sophia
Membro da: 25/03/2014
39.535 Reputazione
107 Guide realizzate
My Xperia z3 was broken back cover if I replace this cover, this waterproof features are still working or not? guys I need your suggestions
Winstonmary Dimagnaong - Replica
Are you sure that the replacement parts mentioned above would work for the Z3 DUAL as well? I believe it has a slightly different size or shape compared to the regular Z3
Shevek - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 53
Tutti i Tempi: 19,938
