Salta al contenuto principale
Sony Xperia Z2 Wi-Fi Antenna Replacement
Cosa ti serve
Panoramica Video
  1. Sony Xperia Z2 Wi-Fi Antenna Replacement, Rear / Battery Cover: passo 1, immagine 1 di 3 Sony Xperia Z2 Wi-Fi Antenna Replacement, Rear / Battery Cover: passo 1, immagine 2 di 3 Sony Xperia Z2 Wi-Fi Antenna Replacement, Rear / Battery Cover: passo 1, immagine 3 di 3
    • Switch off the phone.
    • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Back Cover is plastic.
  2. Sony Xperia Z2 Wi-Fi Antenna Replacement: passo 2, immagine 1 di 3 Sony Xperia Z2 Wi-Fi Antenna Replacement: passo 2, immagine 2 di 3 Sony Xperia Z2 Wi-Fi Antenna Replacement: passo 2, immagine 3 di 3
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  3. Sony Xperia Z2 Wi-Fi Antenna Replacement: passo 3, immagine 1 di 2 Sony Xperia Z2 Wi-Fi Antenna Replacement: passo 3, immagine 2 di 2
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
  4. Sony Xperia Z2 Wi-Fi Antenna Replacement, Battery: passo 4, immagine 1 di 3 Sony Xperia Z2 Wi-Fi Antenna Replacement, Battery: passo 4, immagine 2 di 3 Sony Xperia Z2 Wi-Fi Antenna Replacement, Battery: passo 4, immagine 3 di 3
  5. Sony Xperia Z2 Wi-Fi Antenna Replacement, Wi-Fi Antenna: passo 5, immagine 1 di 3 Sony Xperia Z2 Wi-Fi Antenna Replacement, Wi-Fi Antenna: passo 5, immagine 2 di 3 Sony Xperia Z2 Wi-Fi Antenna Replacement, Wi-Fi Antenna: passo 5, immagine 3 di 3
    • Unscrew the screw and remove the Wi-Fi Antenna.
Conclusione
Altre 11 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.308 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.535 Guide realizzate
3 Commenti
Continu your learning
jafar khalili - Replica
hi got my Xperia z replace the broken screen and I was told that the antenna is broke, wait over week to get fixed and still the antenna is so weak I couldn't load my Face Book
kalipatamar - Replica
This guide seems to have been written just to promote the author’s own website. The advice is very poor, misleading and unhelpful.
(1) Removing the back panel will destroy it. All intending any repairs should have a replacement panel available before beginning.
(2) Replacing battery is as described.
(3) Author does not identify the wifi antenna correctly, nor supply advice on replacing it. Actually the wifi antenna is located at the lower right corner of the Xperia Z2 not upper left as shown. A connector wire runs along the edge in a groove and leads up to a connection on the motherboard. To replace wifi antenna unclip the connector, unscrew the mini circuit board, then reverse the steps with new board/connector.
MooMooUK - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 37
Tutti i Tempi: 21,907
