Introduzione
Sony Xperia Z2 (D6502, D6503, and D6543) - How to disassemble the phone and replace the Earpiece.
Please SUBSCRIBE to my channel ツ
Strumenti
Nessun attrezzo richiesto.
Panoramica Video
Switch off the phone. If you can't switch it off, you can use the OFF button near to the SIM card Tray. Warm the Back Cover. You can use a hairdryer.
  • Switch off the phone.
  • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
  • Warm the Back Cover. You can use a hairdryer.
  • Be careful, the Back Cover is plastic.
Aggiungi Commento
Use a small suction cup and plastic tools for separating the Rear panel. There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s. There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  • Use a small suction cup and plastic tools for separating the Rear panel.
  • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
Aggiungi Commento
Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape). Please SUBSCRIBE to my channel  ツ
  • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
  • Please SUBSCRIBE to my channel ツ
Should include the information about the NFC antenna.
Sounds like a dealbreaker for some people.
Diogo Pinheiro - Replica
What about it?
Makos - Replica
Disconnect the Battery Flex Cable and remove the two Philips screws. Li-Polymer Battery, 3.8V, 3200mAh Part number: LIS1543ERPC
Did you use the custom adhesive or the 3M double sided tape?
kelvinteohbc - Replica
Disconnect one by one: Magnetic Charging Dock Flex Cable
  • Disconnect one by one:
    • Magnetic Charging Dock Flex Cable
    • Volume / Power Button and Microphone Flex Cable
    • Main Camera
    • Audio Jack and Light Sensor Flex cable
    • Coaxial Antenna Cable
I know it should probably be obvious, but just make sure you’ve removed any MicroSD card and the SIM card tray before trying to lift out the board, as otherwise they’ll prevent it from lifting :)
Also, I had to peel off one side of the strip of black tape at the top right (visible in the photos, but not mentioned)
Edward Millen - Replica
Took the Logic Board, making it pick up first on the left side Be careful not to tear up a cable. .
Aggiungi Commento
Earpiece
Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
ZFix
Membro da: 09/12/2013
150.367 Reputazione
424 Guide realizzate
Master Techs Membro di Master Techs
Community
274 Membri
713 Guide realizzate
Would be nice with a comment on how to remove the earpiece.
Since the phone is waterresistance the headjack and earpiece are taped to the body which makes that you need to buy a new sparepart, but look out on ebay that you get a part with tape to it.
Claes - Replica
After having done the removal of the earpiece you will have to, either buy a new adhesive for the earpice or a new earpiece. But be aware some spareparts are sold without adhesive.
Claes -
I accidentally torn apart one of the cables( vibrate cable:the brown one) I'm messed up! Vibration not working. What can I do? Where can I buy one of those cables? Please reply!
Mahtab - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 77
Tutti i Tempi: 5,947
