Salta al contenuto principale
Sony Xperia U Rear Facing Camera Replacement
Cosa ti serve
  1. Sony Xperia U Rear Facing Camera Replacement, Battery: passo 1, immagine 1 di 1
    • Set the phone screen down on a clean flat, surface.
    • Insert the plastic opening tool into the groove located between the body of the phone, and the back plate protecting the battery.
    • Open the back of the device by prying around the sides of the back panel using the plastic opening tool.
  2. Sony Xperia U Rear Facing Camera Replacement: passo 2, immagine 1 di 1
    • Insert the plastic opening tool in between the battery and the phone body.
    • Pry up on the side of battery, and remove it.
  3. Sony Xperia U Rear Facing Camera Replacement, Motherboard: passo 3, immagine 1 di 1
    • Remove the bottom cover of the phone using the plastic opening tool.
  4. Sony Xperia U Rear Facing Camera Replacement: passo 4, immagine 1 di 1
    • Remove the five 5.47mm and one 5.18mm Torx head screws using a Phillips #0 screwdriver.
  5. Sony Xperia U Rear Facing Camera Replacement: passo 5, immagine 1 di 1
    • Carefully remove the back cover using the plastic opening tool.
  6. Sony Xperia U Rear Facing Camera Replacement: passo 6, immagine 1 di 1
    • Pry up on the right side of the motherboard using the plastic opening tool.
  7. Sony Xperia U Rear Facing Camera Replacement: passo 7, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Carefully detach the flex cable using a pair of tweezers.
  8. Sony Xperia U Rear Facing Camera Replacement, Rear Facing Camera: passo 8, immagine 1 di 1
    Compra
    • Use the tweezers to detach the flex cable to remove the camera.
Conclusione
Bader
Membro da: 10/07/14
545 Reputazione
4 Guide realizzate
USF Tampa, Team 7-2, Leahy Fall 2014 Membro di USF Tampa, Team 7-2, Leahy Fall 2014
USFT-LEAHY-F14S7G2
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 886
