Introduzione
I will teach you how to reach the camera and replace it.
Parti
Nessuna parte richiesta.
Use the plastic opening tool to pry the top plastic section off. Use the plastic opening tool to pry the top plastic section off. Use the plastic opening tool to pry the top plastic section off.
  • Use the plastic opening tool to pry the top plastic section off.
Aggiungi Commento
Use the plastic opening tool to pry the bottom plastic section off. Use the plastic opening tool to pry the bottom plastic section off.
  • Use the plastic opening tool to pry the bottom plastic section off.
Aggiungi Commento
Remove the four 5mm screws. Use the plastic opening tool to pry off the back. Use the plastic opening tool to pry off the back.
  • Remove the four 5mm screws.
  • Use the plastic opening tool to pry off the back.
Aggiungi Commento
Use the plastic opening tool to detach the ribbon running across the battery. Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard. Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
  • Use the plastic opening tool to detach the ribbon running across the battery.
  • Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
Aggiungi Commento
Use the plastic opening tool to unlatch the cord's ends off the motherboard and loud speaker module. The cord can be located on the right side of the phone. Use the plastic opening tool to unlatch the cord's ends off the motherboard and loud speaker module. The cord can be located on the right side of the phone.
  • Use the plastic opening tool to unlatch the cord's ends off the motherboard and loud speaker module. The cord can be located on the right side of the phone.
Aggiungi Commento
Use the Phillips #00 to remove the 3 5mm screws. Lift the plastic cover off. Use the plastic opening tool to pry the motherboard out of the phone shell.
  • Use the Phillips #00 to remove the 3 5mm screws.
  • Lift the plastic cover off.
  • Use the plastic opening tool to pry the motherboard out of the phone shell.
Aggiungi Commento
'Use the plastic opening tool to detach the camera from the motherboard.' The camera attachment is on the back of the motherboard. The camera attachment is on the back of the motherboard.
  • 'Use the plastic opening tool to detach the camera from the motherboard.'
  • The camera attachment is on the back of the motherboard.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Adam Giniger
Membro da: 22/09/2014
1.136 Reputazione
8 Guide realizzate
USF Tampa, Team 4-4, Brown Fall 2014 Membro di USF Tampa, Team 4-4, Brown Fall 2014
USFT-BROWN-F14S4G4
3 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 125
