Introduzione
Removing this part is hard for the first time because the manufacturer used adhesive to keep it in place.
Cosa ti serve
Use the plastic opening tool to pry the top plastic section off.
Use the plastic opening tool to pry the bottom plastic section off.
Remove the four 5mm screws.
Use the plastic opening tool to pry off the back.
Use the plastic opening tool to detach the ribbon running across the battery.
Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
Altre 4 persone hanno completato questa guida.
