Introduzione
If the LCD display of your phone is broken, in this manual we will show you, how to disassemble the phone and how to change it.
Please SUBSCRIBE to my channel ツ
Panoramica Video
Switch-off the phone and remove the battery. Switch-off the phone and remove the battery. Switch-off the phone and remove the battery.
  • Switch-off the phone and remove the battery.
Aggiungi Commento
The small bottom bezel is held by 2x locking clips. Preferably use plastic tools for disassembling. Preferably use plastic tools for disassembling.
  • The small bottom bezel is held by 2x locking clips.
  • Preferably use plastic tools for disassembling.
Aggiungi Commento
There are 4x silver screws and 3x black screws. The rear cover is held by 5x locking clips. Two of them, at the bottom side are more hard for unlocking. You can use a screwdriver or other metal tool to unlock them.
  • There are 4x silver screws and 3x black screws.
  • The rear cover is held by 5x locking clips.
  • Two of them, at the bottom side are more hard for unlocking. You can use a screwdriver or other metal tool to unlock them.
Aggiungi Commento
Remove the back cover. With a plastic tool disconnect one by one: LCD Display flex cable
  • Remove the back cover.
  • With a plastic tool disconnect one by one:
    • LCD Display flex cable
    • Touchscreen flex cable
    • Menu Buttons Board flex cable
    • Coaxial Wire Antenna cable
Does the xperia e c1504 dual touch digitizer suits for xperia e c1504 single sim
Ratheesh V.T - Replica
Carefully remove the main board. Carefully remove the main board.
  • Carefully remove the main board.
Aggiungi Commento
Disconnect the other side of the flex cable and remove the Home Buttons board. Unstick the camera button. Unstick the camera button.
  • Disconnect the other side of the flex cable and remove the Home Buttons board.
  • Unstick the camera button.
Aggiungi Commento
The touch screen is stuck to the frame with double side adhesive tape. By using plastic tools gently start separating. At the bottom is glued on firmly because the bonded surface is larger.
  • The touch screen is stuck to the frame with double side adhesive tape.
  • By using plastic tools gently start separating.
  • At the bottom is glued on firmly because the bonded surface is larger.
  • Use a hot air to make separating more easy and safety.
Aggiungi Commento
With a plastic tool, carefully separate the LCD display from the touch screen. Clear the LCD Display from the old adhesive tape. Clear the LCD Display from the old adhesive tape.
  • With a plastic tool, carefully separate the LCD display from the touch screen.
  • Clear the LCD Display from the old adhesive tape.
Aggiungi Commento
Install the new LCD into the frame and put adhesive tape. Be careful not to cover the holes (for the speaker, menu buttons etc.). Install the Touchscreen. Install the Touchscreen.
  • Install the new LCD into the frame and put adhesive tape. Be careful not to cover the holes (for the speaker, menu buttons etc.).
  • Install the Touchscreen.
Aggiungi Commento
Aggiungi Commento
Conclusione
ZFix
Membro da: 09/12/2013
150.367 Reputazione
424 Guide realizzate
Master Techs Membro di Master Techs
Community
274 Membri
713 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 27
Ultimi 30 Giorni: 114
Tutti i Tempi: 10,044
