Salta al contenuto principale
Sony Xperia Z - Password Removal, Firmware Update with PC Companion
Panoramica Video
  1. Sony Xperia Z - Password Removal, Firmware Update with PC Companion, Sony Xperia Z - Password Removal, Firmware Update with PC Companion: passo 1, immagine 1 di 3 Sony Xperia Z - Password Removal, Firmware Update with PC Companion, Sony Xperia Z - Password Removal, Firmware Update with PC Companion: passo 1, immagine 2 di 3 Sony Xperia Z - Password Removal, Firmware Update with PC Companion, Sony Xperia Z - Password Removal, Firmware Update with PC Companion: passo 1, immagine 3 di 3
  2. Sony Xperia Z - Password Removal, Firmware Update with PC Companion: passo 2, immagine 1 di 2 Sony Xperia Z - Password Removal, Firmware Update with PC Companion: passo 2, immagine 2 di 2
    • Install Sony PC Companion in your PC.
  3. Sony Xperia Z - Password Removal, Firmware Update with PC Companion: passo 3, immagine 1 di 3 Sony Xperia Z - Password Removal, Firmware Update with PC Companion: passo 3, immagine 2 di 3 Sony Xperia Z - Password Removal, Firmware Update with PC Companion: passo 3, immagine 3 di 3
    • From here you can update your firmware, but when you connect the phone, it must be switched on and not in security or password screen.
    • We will start "Support Zone" because from here we can flash the phone from switched off state regardless of whether there is a password.
    • Now start "Phone / Tablet Software Update".
  4. Sony Xperia Z - Password Removal, Firmware Update with PC Companion: passo 4, immagine 1 di 3 Sony Xperia Z - Password Removal, Firmware Update with PC Companion: passo 4, immagine 2 di 3 Sony Xperia Z - Password Removal, Firmware Update with PC Companion: passo 4, immagine 3 di 3
    • Connect your laptop to power supply since the update of your phone will take some time.
    • Now choose "repair my phone / tablet". By this way you can fully erase your phone and remove any security password, PIN etc., or change firmware if your phone have OS problem and can't be powered on correctly.
    • This is your last warning about losing your personal data.
  5. Sony Xperia Z - Password Removal, Firmware Update with PC Companion: passo 5, immagine 1 di 2 Sony Xperia Z - Password Removal, Firmware Update with PC Companion: passo 5, immagine 2 di 2
    • PC Companion will download some files to prepare your PC for software update
    • Your phone / tablet must be at last 80% for the update to proceed safely!
  6. Sony Xperia Z - Password Removal, Firmware Update with PC Companion: passo 6, immagine 1 di 2 Sony Xperia Z - Password Removal, Firmware Update with PC Companion: passo 6, immagine 2 di 2
    • Select the model of your phone.
    • You should not confuse the model.
  7. Sony Xperia Z - Password Removal, Firmware Update with PC Companion: passo 7, immagine 1 di 3 Sony Xperia Z - Password Removal, Firmware Update with PC Companion: passo 7, immagine 2 di 3 Sony Xperia Z - Password Removal, Firmware Update with PC Companion: passo 7, immagine 3 di 3
    • The USB cable must be connected only to the PC.
    • Turn off the phone.
    • Press and hold the Volume Down button while plugging the cable into your phone.
    • Once connected, PC Companion will download necessary firmware and will upload it to your phone.
  8. Sony Xperia Z - Password Removal, Firmware Update with PC Companion: passo 8, immagine 1 di 3 Sony Xperia Z - Password Removal, Firmware Update with PC Companion: passo 8, immagine 2 di 3 Sony Xperia Z - Password Removal, Firmware Update with PC Companion: passo 8, immagine 3 di 3
    • Your PC must recognize your phone like SOMC Flash Device.
    • If you have a problem with drivers (your PC can't recognize your phone), search in the internet for "S1Boot Fastboot" drivers or use the link below.
    • Android WinUSB drivers
  9. Sony Xperia Z - Password Removal, Firmware Update with PC Companion: passo 9, immagine 1 di 2 Sony Xperia Z - Password Removal, Firmware Update with PC Companion: passo 9, immagine 2 di 2
    • When PC Companion finished with update process, disconnect the phone and switch it on.
    • Now your phone is in factory condition, with erased custom data and without password protection.
    • Did you do it successfully?
    • Please SUBSCRIBE to my channel ツ
Conclusione
Altre 32 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
195.889 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
329 Membri
1.451 Guide realizzate
4Commenti sulla guida
the Sony Xperia Z C0682 is not in the model list. What should I do ?
Warren Razon - Replica
pls i have sony xperia Zc c80682 and the touch is not working
daniel bentil addison - Replica
thanks it works
Aung kyaw Oo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 77
Tutti i Tempi: 64,476
