Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers. Insert plastic opening tool in the corner of device and slide along edges to separate adhesive. Remove cover
  • Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
  • Insert plastic opening tool in the corner of device and slide along edges to separate adhesive.
  • Remove cover
  • Disconnect battery, to avoid electric shock, by pulling up on the white plastic as shown by the orange box.
Aggiungi Commento
Locate the volume module.
  • Locate the volume module.
  • Remove both screws using the Philips screwdriver.
Aggiungi Commento
Once both screws are removed grab the tweezers.
  • Once both screws are removed grab the tweezers.
  • Then lift up on the module.
Aggiungi Commento
Find the electrical tape connecting the module to the motherboard
  • Find the electrical tape connecting the module to the motherboard
  • Carefully pull out the electrical tape horizontally and remove the volume module from the device.
Aggiungi Commento
Conclusione
Martin Luna
Membro da: 24/09/2014
1.486 Reputazione
5 Guide realizzate
USF Tampa, Team 15-6, Remmell Fall 2014 Membro di USF Tampa, Team 15-6, Remmell Fall 2014
USFT-REMMELL-F14S15G6
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 29
Tutti i Tempi: 1,701
