Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers. Insert plastic opening tool in the corner of device and slide along edges to separate adhesive Remove cover
  • Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
  • Insert plastic opening tool in the corner of device and slide along edges to separate adhesive
  • Remove cover
Aggiungi Commento
Locate the SD card reader in the bottom left hand corner
  • Locate the SD card reader in the bottom left hand corner
  • Remove all screws connecting the metal plate to the device.
Aggiungi Commento
After all the screws have been removed lift the circuit board up to wiggle free.
  • After all the screws have been removed lift the circuit board up to wiggle free.
Aggiungi Commento
After Wiggled free place the tweezers on the piece of electrical tape connecting it to the device.
  • After Wiggled free place the tweezers on the piece of electrical tape connecting it to the device.
  • Once placed there lift up and disconnect the SD card reader from the device.
Aggiungi Commento
Conclusione
Martin Luna
Membro da: 24/09/2014
1.486 Reputazione
5 Guide realizzate
USF Tampa, Team 15-6, Remmell Fall 2014 Membro di USF Tampa, Team 15-6, Remmell Fall 2014
USFT-REMMELL-F14S15G6
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,350
