Introduzione
This guide will assist with the replacement of the Sony Vaio PCG-7184L's optical drive. Please review the Troubleshooting Guide before replacing your optical drive.
Parti
Nessuna parte richiesta.
Locate and unscrew the two highlighted 8 mm Phillips #1 screws.
  • Locate and unscrew the two highlighted 8 mm Phillips #1 screws.
  • There will be three dots next to the desired screws
Aggiungi Commento
Grip the cover of the optical drive and slide it out.
  • Grip the cover of the optical drive and slide it out.
  • If it does not come out, do not force it. Double check to make sure the screws are entirely removed.
Aggiungi Commento
Conclusione
Kevin McGowan
Membro da: 22/04/2014
512 Reputazione
4 Guide realizzate
Cal Poly, Team 9-17, Regan Spring 2014 Membro di Cal Poly, Team 9-17, Regan Spring 2014
CPSU-REGAN-S14S9G17
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,097
