Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer. Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
  • Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
Aggiungi Commento
Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer. Be sure to avoid headphone jack when removing back cover by lifting cover away from computer and up.
  • Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
  • Be sure to avoid headphone jack when removing back cover by lifting cover away from computer and up.
Aggiungi Commento
Lift off back cover to access inner components of computer.
  • Lift off back cover to access inner components of computer.
Aggiungi Commento
Remove the three 1mm Phillips #0 screws surrounding the fan. Loosen the three 1mm Phillips #0 screws. These screws will stay captive to the heatsink.
  • Remove the three 1mm Phillips #0 screws surrounding the fan.
  • Loosen the three 1mm Phillips #0 screws. These screws will stay captive to the heatsink.
Aggiungi Commento
Use tweezers to carefully unplug the fan connector. Use tweezers to carefully unplug the fan connector. Use tweezers to carefully unplug the fan connector.
  • Use tweezers to carefully unplug the fan connector.
Aggiungi Commento
Use the Plastic Opening Tool to gently remove the heat sink and fan assembly from the computer. Important: Follow the How to Apply Thermal Paste guide to replace the thermal paste before reassembling your device.
  • Use the Plastic Opening Tool to gently remove the heat sink and fan assembly from the computer.
  • Important: Follow the How to Apply Thermal Paste guide to replace the thermal paste before reassembling your device.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Marii
Membro da: 08/01/2015
546 Reputazione
3 Guide realizzate
Cal Poly, Team 21-19, Maness Winter 2015 Membro di Cal Poly, Team 21-19, Maness Winter 2015
CPSU-MANESS-W15S21G19
4 Membri
6 Guide realizzate
Could you also maybe do a tutorial on Sony Vaio Fit 13? http://www.laptoppartstore.com/replace--... Any luck figuring out how the fan may be detached and re-attached to the heatsink? Also, I notice a very specific type of taping... where can one procure those?
Abhishek D - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 72
Tutti i Tempi: 2,864
