Introduzione
This guide will inform readers on how to safely uninstall the battery of the Sony VAIO VPC-EB33FM laptop.
Strumenti
Nessun attrezzo richiesto.
Parti
If the laptop isn't turned off, then do so by holding down the power button. Turn the laptop onto its backside.
  • If the laptop isn't turned off, then do so by holding down the power button.
  • Turn the laptop onto its backside.
Aggiungi Commento
Locate the battery below the screen attachment.
  • Locate the battery below the screen attachment.
  • The battery is shaped as a long rectangle with rounded edges.
Aggiungi Commento
Press into the release button while holding the unlock button in position.
  • Press into the release button while holding the unlock button in position.
Aggiungi Commento
Lift the battery out at the notch while holding the release button. Lift the battery out at the notch while holding the release button.
  • Lift the battery out at the notch while holding the release button.
Aggiungi Commento
Conclusione
Kevin
Membro da: 11/01/2013
466 Reputazione
3 Guide realizzate
Cal Poly, Team 18-39, Regan Winter 2013 Membro di Cal Poly, Team 18-39, Regan Winter 2013
CPSU-REGAN-W13S18G39
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,961
