Salta al contenuto principale
Sony VAIO PCG-933A Floppy Disk Drive Replacement
  1. Sony VAIO PCG-933A Floppy Disk Drive Replacement, Battery: passo 1, immagine 1 di 2 Sony VAIO PCG-933A Floppy Disk Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the laptop upside down so that the top is sitting on a flat surface.
    • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  2. Sony VAIO PCG-933A Floppy Disk Drive Replacement: passo 2, immagine 1 di 3 Sony VAIO PCG-933A Floppy Disk Drive Replacement: passo 2, immagine 2 di 3 Sony VAIO PCG-933A Floppy Disk Drive Replacement: passo 2, immagine 3 di 3
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
  3. Sony VAIO PCG-933A Floppy Disk Drive Replacement, Floppy Disk Drive: passo 3, immagine 1 di 1
    • With the laptop facing you, turn the laptop upside down.
  4. Sony VAIO PCG-933A Floppy Disk Drive Replacement: passo 4, immagine 1 di 3 Sony VAIO PCG-933A Floppy Disk Drive Replacement: passo 4, immagine 2 di 3 Sony VAIO PCG-933A Floppy Disk Drive Replacement: passo 4, immagine 3 di 3
    • Locate the release switch in the center of the laptop, shown here.
    • Slide the switch, and hold in place. The floppy disk drive is now free and should easily slide out.
  5. Sony VAIO PCG-933A Floppy Disk Drive Replacement: passo 5, immagine 1 di 1
    • To replace, insert the new floppy disk drive with the wording facing down.
Conclusione
Sara Lillard
Membro da: 04/11/11
165 Reputazione
8 Guide realizzate
Cal Poly, Team 12-36, Maness Spring 2011 Membro di Cal Poly, Team 12-36, Maness Spring 2011
CPSU-MANESS-S11S12G36
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,994
