Introduzione
Repairing/replacing the DVD drive.
Parti
Nessuna parte richiesta.
Turn the laptop upside down The battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  • Turn the laptop upside down
  • The battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
Aggiungi Commento
As shown by the arrow, slide the plastic cover up and then pull out and downwards. You should now be able to pull the battery out. You should now be able to pull the battery out.
  • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
  • You should now be able to pull the battery out.
Aggiungi Commento
Remove the four 16mm Phillips screws bordering the edge of the laptop, indicated here.
  • Remove the four 16mm Phillips screws bordering the edge of the laptop, indicated here.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Remove the 4mm Phillips screw on the right rear side of the laptop next to the audio ports. This will release the speaker grille.
  • Remove the 4mm Phillips screw on the right rear side of the laptop next to the audio ports.
  • This will release the speaker grille.
Aggiungi Commento
Flip the computer back over and open the screen.
  • Flip the computer back over and open the screen.
Aggiungi Commento
Slide the blue speaker grille (located above the keyboard) to the right and gently pull upward.  The grille will still be connected by a white electrical strip. Carefully pull out the white electrical strip. Carefully pull out the white electrical strip.
  • Slide the blue speaker grille (located above the keyboard) to the right and gently pull upward. The grille will still be connected by a white electrical strip.
  • Carefully pull out the white electrical strip.
Aggiungi Commento
Remove the 4mm Phillips screw in the center (located to the left of the green strip). Carefully pull the green strip straight up to disconnect it. The keyboard can now be removed.
  • Remove the 4mm Phillips screw in the center (located to the left of the green strip).
  • Carefully pull the green strip straight up to disconnect it.
  • The keyboard can now be removed.
Aggiungi Commento
Remove the 4mm Phillips screw that connects the hard drive cage to the DVD drive. Carefully remove the copper wire strip.
  • Remove the 4mm Phillips screw that connects the hard drive cage to the DVD drive.
  • Carefully remove the copper wire strip.
Aggiungi Commento
Slide the DVD drive out. Slide the DVD drive out. Slide the DVD drive out.
  • Slide the DVD drive out.
Aggiungi Commento
Conclusione
Sara Lillard
Membro da: 11/04/2011
93 Reputazione
8 Guide realizzate
Cal Poly, Team 12-36, Maness Spring 2011 Membro di Cal Poly, Team 12-36, Maness Spring 2011
CPSU-MANESS-S11S12G36
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,544
