Introduzione
If the Sony TCM-919 is not recording sound, this guide provides replacement solutions. Comprehensive device opening and dismantling up to microphone replacement will be covered.
Turn the device around so that the back cover if facing upward. Use your thumbs to press down firmly and then push the battery door cover open.
  • Turn the device around so that the back cover if facing upward. Use your thumbs to press down firmly and then push the battery door cover open.
  • Remove any batteries.
Aggiungi Commento
Remove the 5, 5.95mm screws as indicated in the picture using the Phillips head screwdriver.
  • Remove the 5, 5.95mm screws as indicated in the picture using the Phillips head screwdriver.
Aggiungi Commento
Look to the back of the top cover. Desolder the two wires connected to the mircophone using the soldering station.
  • Look to the back of the top cover.
  • Desolder the two wires connected to the mircophone using the soldering station.
Aggiungi Commento
Gently remove the rubber top from the two plastic knobs that hold the microphone in place. Remove the microphone by pulling up.
  • Gently remove the rubber top from the two plastic knobs that hold the microphone in place.
  • Remove the microphone by pulling up.
Aggiungi Commento
Conclusione
Marygayle Martin
Membro da: 23/10/2014
501 Reputazione
5 Guide realizzate
Baylor, Team 4-3, Williams Fall 2014 Membro di Baylor, Team 4-3, Williams Fall 2014
BU-WILLIAMS-F14S4G3
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 201
