Salta al contenuto principale
Sony NWZ-E473 Battery Replacement
Cosa ti serve
  1. Sony NWZ-E473 Battery Replacement, Back Panel: passo 1, immagine 1 di 1
    • Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
  2. Sony NWZ-E473 Battery Replacement: passo 2, immagine 1 di 1
    • Use a plastic opening tool to loosen the bottom portion of device.
  3. Sony NWZ-E473 Battery Replacement: passo 3, immagine 1 di 1
    • Use a plastic opening tool to loosen the top panel of the device.
  4. Sony NWZ-E473 Battery Replacement: passo 4, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws located on the portion under the top panel of the device.
  5. Sony NWZ-E473 Battery Replacement: passo 5, immagine 1 di 3 Sony NWZ-E473 Battery Replacement: passo 5, immagine 2 di 3 Sony NWZ-E473 Battery Replacement: passo 5, immagine 3 di 3
    • Remove the back plate from the device.
  6. Sony NWZ-E473 Battery Replacement, Battery: passo 6, immagine 1 di 2 Sony NWZ-E473 Battery Replacement, Battery: passo 6, immagine 2 di 2
    • Peel back the layer of tape along with the processor, which is located just below the battery, using the tweezers and the spudger.
  7. Sony NWZ-E473 Battery Replacement: passo 7, immagine 1 di 2 Sony NWZ-E473 Battery Replacement: passo 7, immagine 2 di 2
    • Slide a prying tool underneath the top portion of the battery and lift it from the case.
  8. Sony NWZ-E473 Battery Replacement: passo 8, immagine 1 di 1
    • Remove the stickers from the battery terminals, which are on the underside of the battery.
  9. Sony NWZ-E473 Battery Replacement: passo 9, immagine 1 di 1
    • Use a soldering iron to remove the wires from the red and the black terminals.
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team 17-6, Watkins Winter 2015 Membro di USF Tampa, Team 17-6, Watkins Winter 2015
USFT-WATKINS-W15S17G6
4 Membri
5 Guide realizzate
2 Commenti
Hi their I have a Sony nwz-e355 walkman I want to replace the battery in it cause I thinks it's done I see u do a replacement for the e473 wondering if u have e355 batteries or will this e473 battery work in my walkman both need to be soildered in any feed back would help
Derek Hebert - Replica
I have the same model. I have 2 of them purchased years ago from Ubid.com. A very cool device. SONY ought to service them when the batteries fadeā€¦
guy lewit -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 37
Tutti i Tempi: 9,502
