Introduzione
Use this guide to remove the front and back panels covering the housing of the camera, allowing you to replace the viewfinder. This guide will take time to complete, but the steps are not very difficult to perform.
Cosa ti serve
If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
To the left of the battery compartment, the SD card needs to be pushed down slightly with your fingers, which will cause the card to eject.
Pull the card out with your fingers.
First, turn the camera upside down.
Press the button located next to silver lens mount and rotate the lens counterclockwise.
Pull the lens away from the camera body.
Start by removing the two 5/32" #00 screws on the bottom of the camera using the Phillips #00 screwdriver.
Starting at the bottom, gently pry the back panel away from the body of the camera using your fingers.
Once the back panel is free from the body, rotate the camera such that back is facing you and pull the back panel past the screen by rotating it to fit around the screen.
Set the back panel aside.
Remove the two 3/32" #00 screws located next to the viewfinder using the Phillips #00 screwdriver.
Using the tweezers, unhook the flexible circuit board from the metal tab on the right of the viewfinder by rotating it to the left.
Altre 9 persone hanno completato questa guida.
4 Commenti
A very handy set of instructions to have for working on an Next. Someone forced the top cover off the flash/strobe assembly of my Nex7 with their fingernail instead of using the push button. Consequently they damaged the black plastic top cover and broke the small coil spring that keeps the flash/strobe lense pointing forward. Are there any guides to help me remove the damaged assembly in order to fit an OEM replacement assembly? I reside in the UK, and the main Sony repair centre informs me that they can't obtain a new strobe/flash assembly. Does anybody know where I could obtain an OEM black top assembly? Are there any high quality direct replacement aftermarket compatible ones (I'm sure the Sony part is manufactured by a supplier to Sony for assembly of the camera) that can be recommended to fit the Nex 7?
Regards,
Sam Ellis
(Scotland, UK)
Hi, i want to buy nex7 viewfinder. Where can i find it? Sorry by me english
