Salta al contenuto principale
Sony NEX-5R Main Navigation Button Replacement
Cosa ti serve
  1. Sony NEX-5R Main Navigation Button Replacement, Rear Case: passo 1, immagine 1 di 1
    • Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
  2. Sony NEX-5R Main Navigation Button Replacement: passo 2, immagine 1 di 1
    • Open the HDMI port, and remove the the two (3.5 mm) Phillips screws exposed on that side.
  3. Sony NEX-5R Main Navigation Button Replacement: passo 3, immagine 1 di 1
    • Remove the two 4mm screws from the interior of the battery pack, and one 3.5mm screw from beside it.
  4. Sony NEX-5R Main Navigation Button Replacement: passo 4, immagine 1 di 1
    • Looking at the bottom of the camera, use the spudger to lift the rear case away from the camera body.
  5. Sony NEX-5R Main Navigation Button Replacement: passo 5, immagine 1 di 2 Sony NEX-5R Main Navigation Button Replacement: passo 5, immagine 2 di 2
    • Using the spudger again, carefully pry from the top of the camera to remove the back frame.
    • The back frame is fragile, so use the spudger gently.
  6. Sony NEX-5R Main Navigation Button Replacement: passo 6, immagine 1 di 1
    • The back case should now be removed and look like this.
  7. Sony NEX-5R Main Navigation Button Replacement, Main Navigation Button: passo 7, immagine 1 di 1
    • Use spudger to pull the lead out from its housing.
  8. Sony NEX-5R Main Navigation Button Replacement: passo 8, immagine 1 di 2 Sony NEX-5R Main Navigation Button Replacement: passo 8, immagine 2 di 2
    • Squeeze the lead with the tweezers and hold the lead teeth tightly with your fingers. Pull straight out to disconnect.
  9. Sony NEX-5R Main Navigation Button Replacement: passo 9, immagine 1 di 2 Sony NEX-5R Main Navigation Button Replacement: passo 9, immagine 2 di 2
    • The navigation button component should now be separate and able to be replaced with new component. The camera and navigation button should appear as shown.
Conclusione
Altre 3 persone hanno completato questa guida.
Emily Trujillo
Membro da: 04/08/14
1.114 Reputazione
6 Guide realizzate
Cal Poly, Team 8-9, Regan Spring 2014 Membro di Cal Poly, Team 8-9, Regan Spring 2014
CPSU-REGAN-S14S8G9
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 29
Tutti i Tempi: 3,737
