Salta al contenuto principale
Sony M-430 Microcassette-Corder Speaker Replacement
Cosa ti serve
  1. Sony M-430 Microcassette-Corder Speaker Replacement, Battery: passo 1, immagine 1 di 1
    • Find the arrow on the battery cover on the back of the device.
    • While pressing down on the arrow, slide the cover towards the bottom of the recorder until it clicks.
  2. Sony M-430 Microcassette-Corder Speaker Replacement: passo 2, immagine 1 di 2 Sony M-430 Microcassette-Corder Speaker Replacement: passo 2, immagine 2 di 2
    • Lift the cover and remove the batteries.
  3. Sony M-430 Microcassette-Corder Speaker Replacement, Back Cover: passo 3, immagine 1 di 2 Sony M-430 Microcassette-Corder Speaker Replacement, Back Cover: passo 3, immagine 2 di 2
    • Remove the battery cover by first tilting it so it is at a right angle with the rest of the device.
    • Next, twist it to the side as shown in the second picture. The lid should simply snap off.
    • Be careful not to apply too much force, as the lid may break.
  4. Sony M-430 Microcassette-Corder Speaker Replacement: passo 4, immagine 1 di 2 Sony M-430 Microcassette-Corder Speaker Replacement: passo 4, immagine 2 di 2
    • Use a #00 Phillips head screwdriver to remove the four (1.7x16 mm) screws from the back case.
    • Next, use the same screwdriver to unscrew the (1.7X5 mm) screw, which is located inside the battery compartment.
  5. Sony M-430 Microcassette-Corder Speaker Replacement: passo 5, immagine 1 di 1
    • Use a spudger to push in the two tabs located on the bottom of the device.
    • It works best to push the tabs at an upward angle (towards the top of the battery compartment)
    • It may take a decent amount of force in order to push in the tabs.
  6. Sony M-430 Microcassette-Corder Speaker Replacement: passo 6, immagine 1 di 1
    • With a firm grip on the larger half, remove the back cover by lifting first on the battery area.
    • The back cover should lift cleanly off.
  7. Sony M-430 Microcassette-Corder Speaker Replacement, Speaker: passo 7, immagine 1 di 1
    • The speaker is the large gold circular piece attached under where the batteries would normally be.
    • It is connected to the device with two black wires that run along one side of the motherboard, as shown on the top of the picture.
  8. Sony M-430 Microcassette-Corder Speaker Replacement: passo 8, immagine 1 di 2 Sony M-430 Microcassette-Corder Speaker Replacement: passo 8, immagine 2 di 2
    • Depending on the replacement speaker you have, there are two places you can desolder the wire.
    • If your replacement speaker has a wire already attached to it, desolder the old wire from where it connects to the motherboard.
    • If the replacement speaker has no wire, desolder the old wire where it connects to the broken speaker.
  9. Sony M-430 Microcassette-Corder Speaker Replacement: passo 9, immagine 1 di 2 Sony M-430 Microcassette-Corder Speaker Replacement: passo 9, immagine 2 di 2
    • Unscrew the 2 Phillips head screws (2x2.5 mm) around the edge of the speaker with a #00 Phillips screwdriver.
    • Use a pair of tweezers to remove the black tape on the speaker. Put the tape on the back of the new speaker.
  10. Sony M-430 Microcassette-Corder Speaker Replacement: passo 10, immagine 1 di 1
    • Now that the speaker is detached from the device, simply tilt the device over and let the speaker fall out.
Conclusione
Matt Teare
Membro da: 01/20/12
35 Reputazione
3 Guide realizzate
Cal Poly, Team 10-34, Amido Winter 2012 Membro di Cal Poly, Team 10-34, Amido Winter 2012
CPSU-AMIDO-W12S10G34
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 872
