Parti
Nessuna parte richiesta.
Pull on tab away from the camera by applying pressure with index finger. Pull on tab away from the camera by applying pressure with index finger.
  • Pull on tab away from the camera by applying pressure with index finger.
Aggiungi Commento
Remove the three 3mm Philips #00 screws.
  • Remove the three 3mm Philips #00 screws.
Aggiungi Commento
Place the camera so that the strap is on the table and the lens is facing you. Lift up the Connector. Pull Back the Connector.
  • Place the camera so that the strap is on the table and the lens is facing you.
  • Lift up the Connector.
  • Pull Back the Connector.
  • Remove the Connector.
Aggiungi Commento
Turn the camera so that the screen tab is pointing towards you. Twist the tab clockwise one notch.
  • Turn the camera so that the screen tab is pointing towards you.
  • Twist the tab clockwise one notch.
  • Remove the 3mm Philips #00 screw.
Aggiungi Commento
Remove two 3mm Philips #00 screws on the control board.
  • Remove two 3mm Philips #00 screws on the control board.
Aggiungi Commento
Place the camera so that the lens is facing the bottom. The battery compartment should be facing you.
  • Place the camera so that the lens is facing the bottom.
  • The battery compartment should be facing you.
Aggiungi Commento
Turn camera on its side, resting on the strap.
  • Turn camera on its side, resting on the strap.
  • The bottom of the camera should be facing you.
  • Remove five 3mm Philips #00 screws.
Aggiungi Commento
Close the LCD screen door.
  • Close the LCD screen door.
  • Turn the camera to the eye piece and battery compartment is facing you.
Aggiungi Commento
Pull the entire cabinet panel away from camera.
  • Pull the entire cabinet panel away from camera.
Aggiungi Commento
You have disassembled the cabinet door and got to the speakers.
  • You have disassembled the cabinet door and got to the speakers.
  • Do not try to pry off the entire door, it can remain slightly attached.
Aggiungi Commento
Conclusione
Amber Han
Membro da: 09/09/2014
107 Reputazione
1 Guida realizzata
CSU Fullerton, Team 2-5, Bruce Fall 2014 Membro di CSU Fullerton, Team 2-5, Bruce Fall 2014
CSUF-BRUCE-F14S2G5
4 Membri
2 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 317
