Salta al contenuto principale
Sony Handycam DCR-DVD103 Lens Replacement
Cosa ti serve
  1. Sony Handycam DCR-DVD103 Lens Replacement, Battery: passo 1, immagine 1 di 1
    • Images do not show the camera's battery.
    • On the back of the camera beneath the viewfinder, locate the battery pack.
    • Press the small button.
    • Slide the switch forward.
  2. Sony Handycam DCR-DVD103 Lens Replacement: passo 2, immagine 1 di 1
    • Remove the battery from the camera.
    • To reinsert the battery, slide the battery into the camera.
  3. Sony Handycam DCR-DVD103 Lens Replacement, Outer Cover: passo 3, immagine 1 di 1
    • Using a #00 Phillips screwdriver, remove the six 4.5 mm screws from the camera's bottom.
  4. Sony Handycam DCR-DVD103 Lens Replacement: passo 4, immagine 1 di 2 Sony Handycam DCR-DVD103 Lens Replacement: passo 4, immagine 2 di 2
    • Remove the three 4.5 mm screws beneath the battery.
    • Remove the 2.9 mm screw from the right corner.
    • Remove the two 4.5 mm screws from the battery's right wall.
    • Images do not show the battery.
  5. Sony Handycam DCR-DVD103 Lens Replacement: passo 5, immagine 1 di 1
    • Remove the 4.5 mm screw under the output flap on the front of the camera below the lens.
  6. Sony Handycam DCR-DVD103 Lens Replacement: passo 6, immagine 1 di 2 Sony Handycam DCR-DVD103 Lens Replacement: passo 6, immagine 2 di 2
    • Remove the two 4.5 mm screws at the top of the camera.
    • Remove the 4.5 mm screw from the disk side of the camera (next to the lens).
  7. Sony Handycam DCR-DVD103 Lens Replacement: passo 7, immagine 1 di 2 Sony Handycam DCR-DVD103 Lens Replacement: passo 7, immagine 2 di 2
    • Extend the gray viewfinder, then gently remove the black plastic casing.
    • Caution: Plastic pieces are fragile.
  8. Sony Handycam DCR-DVD103 Lens Replacement: passo 8, immagine 1 di 1
    • Remove the two 2.9 mm screws under the black plastic casing.
  9. Sony Handycam DCR-DVD103 Lens Replacement: passo 9, immagine 1 di 1
    • Gently pull apart the outer silver case and screen.
    • Remove the copper wire strip to detach the case from the camera.
  10. Sony Handycam DCR-DVD103 Lens Replacement, Lens: passo 10, immagine 1 di 1
    • Remove the 4.5 mm thread that connects the lens to the camera body.
  11. Sony Handycam DCR-DVD103 Lens Replacement: passo 11, immagine 1 di 2 Sony Handycam DCR-DVD103 Lens Replacement: passo 11, immagine 2 di 2
    • Remove the two 4.5 mm screws from the bottom left and top left of the lens casing.
    • Remove the two 2.9 mm screws from the top right and bottom right of the lens casing.
  12. Sony Handycam DCR-DVD103 Lens Replacement: passo 12, immagine 1 di 1
    • Gently slide the ribbon cables away from their connections on the motherboard.
    • Caution: Too much force will tear the cables.
  13. Sony Handycam DCR-DVD103 Lens Replacement: passo 13, immagine 1 di 1
    • Remove the 4.5 mm screw that connects the camera body to the lens on the DVD side of the camera.
  14. Sony Handycam DCR-DVD103 Lens Replacement: passo 14, immagine 1 di 3 Sony Handycam DCR-DVD103 Lens Replacement: passo 14, immagine 2 di 3 Sony Handycam DCR-DVD103 Lens Replacement: passo 14, immagine 3 di 3
    • Remove the five 2.9 mm screws connected to the circuit board.
    • Remove the circuit board from the camera.
    • Remove the five copper wires attached to the circuit board.
  15. Sony Handycam DCR-DVD103 Lens Replacement: passo 15, immagine 1 di 2 Sony Handycam DCR-DVD103 Lens Replacement: passo 15, immagine 2 di 2
    • Unscrew the three 2.9 mm black screws to remove the metal bracket from the lens.
  16. Sony Handycam DCR-DVD103 Lens Replacement: passo 16, immagine 1 di 2 Sony Handycam DCR-DVD103 Lens Replacement: passo 16, immagine 2 di 2
    • Remove the two silver 4.5 mm screws from the bottom of the lens.
    • Caution: Be careful with the lens once the screws are removed. The lens contains a small piece of glass that can fall out.
Conclusione
Altre 2 persone hanno completato questa guida.
kaitlin
Membro da: 01/11/11
342 Reputazione
3 Guide realizzate
Cal Poly, Team 7-44, Regan Winter 2011 Membro di Cal Poly, Team 7-44, Regan Winter 2011
CPSU-REGAN-W11S7G44
5 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 4,595
