Salta al contenuto principale
Sony FDL-220R Watchman Button Replacement
Cosa ti serve
  1. Sony FDL-220R Watchman Button Replacement, Remove battery cover and batteries: passo 1, immagine 1 di 2 Sony FDL-220R Watchman Button Replacement, Remove battery cover and batteries: passo 1, immagine 2 di 2
    • Press down on the textured area and push towards the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Button Replacement, Remove screws: passo 2, immagine 1 di 2 Sony FDL-220R Watchman Button Replacement, Remove screws: passo 2, immagine 2 di 2
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Philips #00 screwdriver.
  3. Sony FDL-220R Watchman Button Replacement, Remove back casing: passo 3, immagine 1 di 2 Sony FDL-220R Watchman Button Replacement, Remove back casing: passo 3, immagine 2 di 2
    • Grasp the entire back half of the Watchman's casing.
    • Snap off the casing from the bottom of the device.
    • Gently pull off entire back casing.
  4. Sony FDL-220R Watchman Button Replacement, Remove circuit board: passo 4, immagine 1 di 3 Sony FDL-220R Watchman Button Replacement, Remove circuit board: passo 4, immagine 2 di 3 Sony FDL-220R Watchman Button Replacement, Remove circuit board: passo 4, immagine 3 di 3
    • Carefully grasp the entire circuit board.
    • Pull the circuit board off of the device's plastic casing.
  5. Sony FDL-220R Watchman Button Replacement, Remove/Replace Buttons: passo 5, immagine 1 di 2 Sony FDL-220R Watchman Button Replacement, Remove/Replace Buttons: passo 5, immagine 2 di 2
    • Locate the thee plastic buttons/switches on the sides of the plastic grey casing.
    • Buttons/switches should be simply resting in their slots on the device.
    • Remove all three buttons/switches.
    • If the buttons/switches are dirty, clean them in warm water and dry thoroughly.
    • If one of the buttons/switches is broken, simply replace it with a new one.
    • When replacing, make sure that the slot on the switches faces up.
Conclusione
Sam Putnam
Membro da: 10/22/14
484 Reputazione
4 Guide realizzate
Baylor, Team 4-5, Williams Fall 2014 Membro di Baylor, Team 4-5, Williams Fall 2014
BU-WILLIAMS-F14S4G5
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 241
