Salta al contenuto principale
Sony Ericsson z300 Keypad Replacement
Cosa ti serve
  1. Sony Ericsson z300 Keypad Replacement, Back Phone Cover: passo 1, immagine 1 di 1
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Sony Ericsson z300 Keypad Replacement, Battery: passo 2, immagine 1 di 1
    • Using a fingernail lift the battery out of the phone.
  3. Sony Ericsson z300 Keypad Replacement, Sim Card: passo 3, immagine 1 di 1
    • Slide the sim card out with your thumb.
  4. Sony Ericsson z300 Keypad Replacement, Back Dark Grey Case: passo 4, immagine 1 di 1
    • To remove the back case first remove the four screws shown with a T5 Torx screwdriver
  5. Sony Ericsson z300 Keypad Replacement: passo 5, immagine 1 di 1
    • Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
  6. Sony Ericsson z300 Keypad Replacement: passo 6, immagine 1 di 1
    • Lift up towards the bottom and slide the case off.
  7. Sony Ericsson z300 Keypad Replacement, Motherboard: passo 7, immagine 1 di 1
    • Use a plastic opening tool to lift up the brass colored panel.
  8. Sony Ericsson z300 Keypad Replacement: passo 8, immagine 1 di 1
    • Flip up the yellow tab using a plastic opening tool to disconnect the motherboard from the phone body.
  9. Sony Ericsson z300 Keypad Replacement: passo 9, immagine 1 di 1
    • Work the plastic opening tool around the edges of the motherboard to release it from the clips.
  10. Sony Ericsson z300 Keypad Replacement, Keypad: passo 10, immagine 1 di 1
    • Using a plastic opening tool lift up the keypad to remove it.
Conclusione
Cal Poly, Team 5-15, Maness Fall 2010 Membro di Cal Poly, Team 5-15, Maness Fall 2010
CPSU-MANESS-F10S5G15
4 Membri
26 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,335
