Salta al contenuto principale
Sony Ericsson z300 Front Speaker Replacement
Cosa ti serve
  1. Sony Ericsson z300 Front Speaker Replacement, Back Phone Cover: passo 1, immagine 1 di 1
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Sony Ericsson z300 Front Speaker Replacement, Battery: passo 2, immagine 1 di 1
    • Using a fingernail lift the battery out of the phone.
  3. Sony Ericsson z300 Front Speaker Replacement, Front Phone Cover: passo 3, immagine 1 di 1
    • To remove the front cover, lift up the case with a fingernail in the small slot as shown.
  4. Sony Ericsson z300 Front Speaker Replacement, Front Dark Grey Case: passo 4, immagine 1 di 1
    • To remove the front grey case, remove the two screws shown with a T5 Torx Screwdriver.
  5. Sony Ericsson z300 Front Speaker Replacement: passo 5, immagine 1 di 1
    • Pry up the dark grey case with your fingernail until all four snaps around the top are loose.
  6. Sony Ericsson z300 Front Speaker Replacement: passo 6, immagine 1 di 1
    • Lift up towards the bottom and slide the case off.
  7. Sony Ericsson z300 Front Speaker Replacement, Screens: passo 7, immagine 1 di 1
    • Use a plastic opening tool to lift the black tape off of the ribbon cable connector.
  8. Sony Ericsson z300 Front Speaker Replacement: passo 8, immagine 1 di 1
    • Lift the ribbon cable connector lock using a plastic opening tool.
  9. Sony Ericsson z300 Front Speaker Replacement: passo 9, immagine 1 di 2 Sony Ericsson z300 Front Speaker Replacement: passo 9, immagine 2 di 2
    • Slide the black ribbon cable tray out with a plastic opening tool.
    • Shown in the second picture is the try already slid out.
  10. Sony Ericsson z300 Front Speaker Replacement: passo 10, immagine 1 di 2 Sony Ericsson z300 Front Speaker Replacement: passo 10, immagine 2 di 2
    • Slide the ribbon cable out of the connector.
    • Shown in the second picture is the cable already out.
  11. Sony Ericsson z300 Front Speaker Replacement: passo 11, immagine 1 di 1
    • Use a plastic opening tool to lift up on the screen board and release the clips holding it in place.
    • Lift the entire board out of the phone to remove both screens.
  12. Sony Ericsson z300 Front Speaker Replacement, Front Speaker: passo 12, immagine 1 di 1
    • Use a plastic opening tool to lift the speaker out of its circular slot.
Conclusione
Cal Poly, Team 5-15, Maness Fall 2010 Membro di Cal Poly, Team 5-15, Maness Fall 2010
CPSU-MANESS-F10S5G15
4 Membri
26 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,561
