Introduzione
This guide will show how to remove the speaker.
Parti
Nessuna parte richiesta.
To remove the back cover, use your thumb to press down on the center of case and slide it off.
  • To remove the back cover, use your thumb to press down on the center of case and slide it off.
Aggiungi Commento
Using a fingernail lift the battery out of the phone.
  • Using a fingernail lift the battery out of the phone.
Aggiungi Commento
Slide the sim card out with your thumb.
  • Slide the sim card out with your thumb.
Aggiungi Commento
To remove the back case first remove the four screws shown with a T5 Torx screwdriver
  • To remove the back case first remove the four screws shown with a T5 Torx screwdriver
Aggiungi Commento
Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
  • Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
Aggiungi Commento
Lift up towards the bottom and slide the case off.
  • Lift up towards the bottom and slide the case off.
Aggiungi Commento
Use a plastic opening tool to lift the speaker out of the back case.
  • Use a plastic opening tool to lift the speaker out of the back case.
Aggiungi Commento
Conclusione
Alex Serventi
Membro da: 07/10/2010
50 Reputazione
26 Guide realizzate
Cal Poly, Team 5-15, Maness Fall 2010 Membro di Cal Poly, Team 5-15, Maness Fall 2010
CPSU-MANESS-F10S5G15
4 Membri
26 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 817
