Salta al contenuto principale
Sony Ericsson w600i LCD Replacement
Cosa ti serve
  1. Sony Ericsson w600i LCD Replacement , Disassembling Sony Ericsson w600i Battery Cover: passo 1, immagine 1 di 1
    • Grip the lower portion of the back of the phone and slide downwards.
  2. Sony Ericsson w600i LCD Replacement , Battery: passo 2, immagine 1 di 1
    • Lift battery at the rounded notch near the bottom of the phone.
  3. Sony Ericsson w600i LCD Replacement , Back housing: passo 3, immagine 1 di 1
    • Unscrew the four Torx screws from the backplate.
    • The backplate may begin to separate from the keypad face. Do not try to remove it yet.
    • The screws are T5 Torx screws, 5.6mm.
  4. Sony Ericsson w600i LCD Replacement : passo 4, immagine 1 di 1
    • Swivel the phone open.
  5. Sony Ericsson w600i LCD Replacement : passo 5, immagine 1 di 1
    • Using the Spudger, gently pry up the U-shaped grey cover below the keypad.
    • The cover is secured with adhesive tape. The gentler this is removed, the easier it will be to reassemble.
  6. Sony Ericsson w600i LCD Replacement : passo 6, immagine 1 di 1
    • Remove the two Torx screws from below the cover.
    • These are T5 Torx screws, 8.6mm.
  7. Sony Ericsson w600i LCD Replacement : passo 7, immagine 1 di 1
    • Gently work a spudger or a fingernail between the keypad face and the backplate.
    • The pieces are clipped together most tightly at the bottom loop section.
  8. Sony Ericsson w600i LCD Replacement : passo 8, immagine 1 di 2 Sony Ericsson w600i LCD Replacement : passo 8, immagine 2 di 2
    • Separate the keypad face from the backplate.
    • The keypad keys and the button component are both loose inside the phone, so take note of their orientation in case they become dislodged.
    • Take note of the braided cord's state. Upon reassembly it should be returned to the same orientation.
  9. Sony Ericsson w600i LCD Replacement : passo 9, immagine 1 di 3 Sony Ericsson w600i LCD Replacement : passo 9, immagine 2 di 3 Sony Ericsson w600i LCD Replacement : passo 9, immagine 3 di 3
    • Holding the backplate away from the swivel, remove the 4 small Phillips screws and both stamped struts from the swivel assembly.
    • Note that only the bottom strut has a tab.
    • The screws are Phillips, 2.9mm
  10. Sony Ericsson w600i LCD Replacement : passo 10, immagine 1 di 1
    • The back housing is now disassembled, and the swivel assembly is revealed.
  11. Sony Ericsson w600i LCD Replacement , LCD Section: passo 11, immagine 1 di 2 Sony Ericsson w600i LCD Replacement , LCD Section: passo 11, immagine 2 di 2
    • Remove the four black Phillips screws holding the swivel assembly to the LCD section of the phone.
    • Be mindful of the screws, as they are very small.
    • The screws are Phillips, 2.4mm
  12. Sony Ericsson w600i LCD Replacement : passo 12, immagine 1 di 1
    • Gently remove the grey plastic cover at the top-rear of the LCD section with a spudger.
    • It is secured with adhesive tape, the more gently you remove this piece, the easier reassembly will be later.
  13. Sony Ericsson w600i LCD Replacement : passo 13, immagine 1 di 1
    • Remove the two Torx screws revealed under the grey cover.
    • The screws are Torx T5, 5.6mm
  14. Sony Ericsson w600i LCD Replacement : passo 14, immagine 1 di 1
    • Gently pry off the front face, starting at the bottom slot.
  15. Sony Ericsson w600i LCD Replacement : passo 15, immagine 1 di 1
    • Remove the Torx screws near the buttons.
  16. Sony Ericsson w600i LCD Replacement : passo 16, immagine 1 di 2 Sony Ericsson w600i LCD Replacement : passo 16, immagine 2 di 2
    • Remove the black front plate.
    • Remove the button overlay, taking note of its position for reassembly. There are small grey nubs that correspond to holes in the overlay.
  17. Sony Ericsson w600i LCD Replacement : passo 17, immagine 1 di 1
    • Gently release the small grey retaining clips around the outside of the display assembly.
    • Separate the display assembly from its backplate.
    • Take care; some of the side buttons may dislodge as the backplate is separated.
    • The LCD section is now disassembled.
  18. Sony Ericsson w600i LCD Replacement , LCD Replacement: passo 18, immagine 1 di 2 Sony Ericsson w600i LCD Replacement , LCD Replacement: passo 18, immagine 2 di 2
    • The LCD display is connected to the device with a small flex cable. To release the cable, flip the small handle on the connector to an upright position.
  19. Sony Ericsson w600i LCD Replacement : passo 19, immagine 1 di 2 Sony Ericsson w600i LCD Replacement : passo 19, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Gently pull the flex cable downwards with a pair of tweezers.
  20. Sony Ericsson w600i LCD Replacement : passo 20, immagine 1 di 2 Sony Ericsson w600i LCD Replacement : passo 20, immagine 2 di 2
    • Gently separate the side button component from the inner casing. It is attached with adhesive.
    • Gently pull the front button component away from the inner casing slightly. It does not need to be removed.
  21. Sony Ericsson w600i LCD Replacement : passo 21, immagine 1 di 1
    • Remove the LCD screen by its white housing, pulling the flex cable through the slot from the other side of the casing.
  22. Sony Ericsson w600i LCD Replacement : passo 22, immagine 1 di 1
    • The LCD has been removed! It can now be replaced with a functioning display.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 16
Tutti i Tempi: 806
