Introduzione
This guide will show you how to install a battery in the Sony Ericsson s710a. It can be used if the current battery is missing or faulty and needs to be replaced.
Strumenti
Nessun attrezzo richiesto.
Parti
Remove the back cover by sliding it off.
  • Remove the back cover by sliding it off.
Aggiungi Commento
Once the back cover is removed, pull out the battery using your finger as shown.
  • Once the back cover is removed, pull out the battery using your finger as shown.
Aggiungi Commento
The battery can now be replaced if desired.
  • The battery can now be replaced if desired.
    • The battery is a 780 mAh rechargeable Lithium Ion battery.
Aggiungi Commento
Conclusione
Replacing the battery is a simple and effective way to get longer battery life.
Mike
Membro da: 21/11/2011
31 Reputazione
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,196
