Introduzione
The thing that emits sound.
Parti
Nessuna parte richiesta.
Remove the back cover and the battery. Remove the back cover and the battery. Remove the back cover and the battery.
  • Remove the back cover and the battery.
Aggiungi Commento
Remove the 4 screws using a T6 precision screwdriver.
  • Remove the 4 screws using a T6 precision screwdriver.
  • Flip open the phone, and keep the back cover facing you.
Aggiungi Commento
Take the plastic opening tool and run it between the phone case and phone body to loosen the key pad while the phone is open. Note: There are 2 clamps that lock it to the phone case (1 on each side).
  • Take the plastic opening tool and run it between the phone case and phone body to loosen the key pad while the phone is open.
  • Note: There are 2 clamps that lock it to the phone case (1 on each side).
Aggiungi Commento
Flip the phone over and lift straight up on the key pad to remove it.
  • Flip the phone over and lift straight up on the key pad to remove it.
  • Be sure to hold the phone flat (parallel to the table), because there are loose parts that may fall out.
Aggiungi Commento
Use the i Pod opening tool to remove the 2 ribbon wires (boxed in the photo) from the logic board.
  • Use the i Pod opening tool to remove the 2 ribbon wires (boxed in the photo) from the logic board.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Gently lift the back of the logic board and then pull outwards. Be careful not to rip the ribbon wire.
  • Gently lift the back of the logic board and then pull outwards. Be careful not to rip the ribbon wire.
Aggiungi Commento
If the parts are loose you can remove the black sim card reader and green vibrator before continuing, otherwise they may fall out. If the parts are loose you can remove the black sim card reader and green vibrator before continuing, otherwise they may fall out.
  • If the parts are loose you can remove the black sim card reader and green vibrator before continuing, otherwise they may fall out.
Aggiungi Commento
Close the phone, flip it over, grab the remaining gray covering of the phone and pull it straight up to remove it. There is another piece below     this which will break if you don't pull straight up.
  • Close the phone, flip it over, grab the remaining gray covering of the phone and pull it straight up to remove it.
  • There is another piece below this which will break if you don't pull straight up.
  • Once the cover is removed take off the black piece underneath.
Aggiungi Commento
Remove the face of the phone by sliding down.
  • Remove the face of the phone by sliding down.
Aggiungi Commento
Unscrew the 4 screws connecting the screen to the base using a T6 Precision screwdriver.
  • Unscrew the 4 screws connecting the screen to the base using a T6 Precision screwdriver.
Aggiungi Commento
Use ipod opening tool to pry up the edge of the remaining silver hinge cover. Once it is loose you can pull it off the rest of the way.
  • Use ipod opening tool to pry up the edge of the remaining silver hinge cover.
  • Once it is loose you can pull it off the rest of the way.
Aggiungi Commento
To remove the plastic cover on the screen, run the ipod opening tool along the sides between the cover and the body of the phone (like you did for the keyboard)and gently pry upward until it is loose. Like the keyboard there is one clamp on each side.
  • To remove the plastic cover on the screen, run the ipod opening tool along the sides between the cover and the body of the phone (like you did for the keyboard)and gently pry upward until it is loose.
  • Like the keyboard there is one clamp on each side.
  • Grab the cover at the bottom of the screen (near the hinge) and pull outward while leaving the top (near the speaker) connected.
  • Once the bottom is pulled out far enough the top will be able to disconnect as well.
Aggiungi Commento
Remove the tape on the bottom of the screen so that the screen will be able to come out.
  • Remove the tape on the bottom of the screen so that the screen will be able to come out.
  • There is a finger notch on the top of the screen, gently pull out halfway.
  • Caution: the back of the screen is connected to the base of the phone. So do not pull out or the connection will be broken.
Aggiungi Commento
Use the iPod opening device to remove the ribbon wire where it connects to the screen.
  • Use the iPod opening device to remove the ribbon wire where it connects to the screen.
Aggiungi Commento
Use the iPod opening tool to place under speaker and pop it out.
  • Use the iPod opening tool to place under speaker and pop it out.
  • The wires on the speaker are soldered on so they need to be detached and connected to new speaker.
Aggiungi Commento
Conclusione
Tim
Membro da: 20/04/2010
9 Reputazione
4 Guide realizzate
Cal Poly, Team 7-12, Maness Spring 2010 Membro di Cal Poly, Team 7-12, Maness Spring 2010
CPSU-MANESS-S10S7G12
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 944
