Introduzione
This guide shows how to remove the phone keypad.
Parti
Nessuna parte richiesta.
Remove the back cover and the battery. Remove the back cover and the battery. Remove the back cover and the battery.
  • Remove the back cover and the battery.
Aggiungi Commento
Remove the 4 screws using a T6 precision screwdriver.
  • Remove the 4 screws using a T6 precision screwdriver.
  • Flip open the phone, and keep the back cover facing you.
Aggiungi Commento
Take the plastic opening tool and run it between the phone case and phone body to loosen the key pad while the phone is open. Note: There are 2 clamps that lock it to the phone case (1 on each side).
  • Take the plastic opening tool and run it between the phone case and phone body to loosen the key pad while the phone is open.
  • Note: There are 2 clamps that lock it to the phone case (1 on each side).
Aggiungi Commento
Flip the phone over and lift straight up on the key pad to remove it.
  • Flip the phone over and lift straight up on the key pad to remove it.
  • Be sure to hold the phone flat (parallel to the table), because there are loose parts that may fall out.
Aggiungi Commento
Conclusione
Cal Poly, Team 7-12, Maness Spring 2010 Membro di Cal Poly, Team 7-12, Maness Spring 2010
CPSU-MANESS-S10S7G12
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 2,578
