Introduzione
This is a short and simple guide to button cleaning and repairing
Parti
Nessuna parte richiesta.
The first step in accessing the audio and/or camera buttons is to remove the back case of the phone and then the battery
  • The first step in accessing the audio and/or camera buttons is to remove the back case of the phone and then the battery
Aggiungi Commento
Next, remove eight 5mm screws as shown in the image. Use a T-6 bit.
  • Next, remove eight 5mm screws as shown in the image. Use a T-6 bit.
Aggiungi Commento
Using a case opener (a guitar pick works as well), start on the bottom right side of the phone and undo clips located at the interior sides. Repeat this step for the left side.
  • Using a case opener (a guitar pick works as well), start on the bottom right side of the phone and undo clips located at the interior sides. Repeat this step for the left side.
Aggiungi Commento
The phone should now look like this. The Volume button is indicated by the larger yellow circle, and the camera button is indicated by the smaller and lower yellow circle.
  • The phone should now look like this. The Volume button is indicated by the larger yellow circle, and the camera button is indicated by the smaller and lower yellow circle.
Aggiungi Commento
The volume button (left) and the camera button (right) lift right out of the phone as shown in the picture. From here you can clean them or replace them.
  • The volume button (left) and the camera button (right) lift right out of the phone as shown in the picture. From here you can clean them or replace them.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,391
