Introduzione
Use this guide to replace the front cover or front keyboard.
Insert the edge of an opening tool between the front cover and the phone. Gently pry off the front cover working your way around the edges.
  • Insert the edge of an opening tool between the front cover and the phone.
  • Gently pry off the front cover working your way around the edges.
Aggiungi Commento
Pull the front cover down and away from the phone. The front keypads might come off with the front cover.  Do not lose these.
  • Pull the front cover down and away from the phone.
  • The front keypads might come off with the front cover. Do not lose these.
Aggiungi Commento
Gently peel the keypad away from the phone.
  • Gently peel the keypad away from the phone.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Diego
Membro da: 09/10/2011
307 Reputazione
8 Guide realizzate
Cal Poly, Team 5-31, Amido Fall 2011 Membro di Cal Poly, Team 5-31, Amido Fall 2011
CPSU-AMIDO-F11S5G31
4 Membri
11 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 3,052
