Introduzione
Replacing the keypad requires that the front case be removed.
Parti
Slide the battery cover up and off the phone. Slide the battery cover up and off the phone.
  • Slide the battery cover up and off the phone.
Aggiungi Commento
Pop the battery out of its slot by lifting it up. Pop the battery out of its slot by lifting it up.
  • Pop the battery out of its slot by lifting it up.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Insert the plastic opening tool in between the front case and the back case. Apply downward pressure to make the case lift upwards, thus popping the front case off. Use caution when removing the front case. It may seem stuck but just ease it out.
  • Insert the plastic opening tool in between the front case and the back case.
  • Apply downward pressure to make the case lift upwards, thus popping the front case off.
    • Use caution when removing the front case. It may seem stuck but just ease it out.
Aggiungi Commento
Using the plastic opening tool, press down anywhere on the keypad to separate it from the front case. Using the plastic opening tool, press down anywhere on the keypad to separate it from the front case.
  • Using the plastic opening tool, press down anywhere on the keypad to separate it from the front case.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Nestor Trevino
Membro da: 14/01/2011
139 Reputazione
2 Guide realizzate
Cal Poly, Team 14-10, Forte Winter 2011 Membro di Cal Poly, Team 14-10, Forte Winter 2011
CPSU-FORTE-W11S14G10
5 Membri
16 Guide realizzate
Can you guys tell me where i do get parts for these legacy phones?My jostick died on this phone.Not working at all i only can use the keypad.
Janos Lazar - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 5,147
