Introduzione
This guide will assist you in removing the speaker from your Sony Ericsson T68i.
Parti
Nessuna parte richiesta.
Remove the battery from the back. Remove the battery from the back.
  • Remove the battery from the back.
Aggiungi Commento
Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips. Do not bend it too far down, or else you risk breaking the two bottom clips. Do not bend it too far down, or else you risk breaking the two bottom clips.
  • Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
  • Do not bend it too far down, or else you risk breaking the two bottom clips.
Aggiungi Commento
Unscrew all four Torx T6 screws. Keep in a safe place. Keep in a safe place.
  • Unscrew all four Torx T6 screws.
  • Keep in a safe place.
Aggiungi Commento
After removing the screws, the two halves will separate. If not, then pry them gently apart. After removing the screws, the two halves will separate. If not, then pry them gently apart. After removing the screws, the two halves will separate. If not, then pry them gently apart.
  • After removing the screws, the two halves will separate. If not, then pry them gently apart.
Aggiungi Commento
Remove the circuit board and screen from the device. Use your T6 to remove the 4 screws. Use your T6 to remove the 4 screws.
  • Remove the circuit board and screen from the device.
  • Use your T6 to remove the 4 screws.
Aggiungi Commento
Remove the board and screen. Remove the board and screen. Remove the board and screen.
  • Remove the board and screen.
Aggiungi Commento
Carefully remove the plastic clips holding the screen on the board. Carefully remove the plastic clips holding the screen on the board. Carefully remove the plastic clips holding the screen on the board.
  • Carefully remove the plastic clips holding the screen on the board.
Aggiungi Commento
Gently pry it out the speaker located in the screen housing with a small screwdriver or similar tool. Gently pry it out the speaker located in the screen housing with a small screwdriver or similar tool. Gently pry it out the speaker located in the screen housing with a small screwdriver or similar tool.
  • Gently pry it out the speaker located in the screen housing with a small screwdriver or similar tool.
Aggiungi Commento
Conclusione
Tim Dascomb
Membro da: 13/04/2010
123 Reputazione
13 Guide realizzate
Cal Poly, Team 26-34, Regan Spring 2010 Membro di Cal Poly, Team 26-34, Regan Spring 2010
CPSU-REGAN-S10S26G34
4 Membri
13 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,096
