Introduzione
Please note: you must remove the screws from the back casing before beginning this guide.
Remove 4 screws from battery chamber
  • Remove 4 screws from battery chamber
    • Red - Phillips 0 screwdriver
    • Blue - Torx 6 screwdriver
Aggiungi Commento
Gently pry off back casing
  • Gently pry off back casing
    • Note: work shim or flathead screwdriver around entire seam before attempting to pull off casing. This will reduce the chance of cracking the casing.
Aggiungi Commento
Remove casing to expose camera components
  • Remove casing to expose camera components
Aggiungi Commento
Gently pry open front casing by working a small shim or flathead screwdriver along the entire seam
  • Gently pry open front casing by working a small shim or flathead screwdriver along the entire seam
Aggiungi Commento
Remove front casing by gently lifting it from the phone
  • Remove front casing by gently lifting it from the phone
    • Be careful not to pull off any other delicate pieces
Aggiungi Commento
Keypad should be easy to remove Caution: LCD screen is very fragile. Be careful not to catch the keypad on it while removing.
  • Keypad should be easy to remove
    • Caution: LCD screen is very fragile. Be careful not to catch the keypad on it while removing.
Aggiungi Commento
Conclusione
Abby Evers
Membro da: 04/10/2011
196 Reputazione
12 Guide realizzate
UW Stout, Team 1-6, Zhou Fall 2011 Membro di UW Stout, Team 1-6, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G6
4 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,953
