Remove battery cover
  • Remove battery cover
    • Press down firmly with thumb and slide cover back
Aggiungi Commento
Remove 4 screws from battery chamber
  • Remove 4 screws from battery chamber
    • Red - Phillips 0 screwdriver
    • Blue - Torx 6 screwdriver
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Gently pry off back casing
  • Gently pry off back casing
    • Note: work shim or flathead screwdriver around entire seam before attempting to pull off casing. This will reduce the chance of cracking the casing.
Aggiungi Commento
Remove casing to expose camera components
  • Remove casing to expose camera components
Aggiungi Commento
Conclusione
Abby Evers
Membro da: 04/10/2011
196 Reputazione
12 Guide realizzate
UW Stout, Team 1-6, Zhou Fall 2011 Membro di UW Stout, Team 1-6, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G6
4 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 3,179
