Salta al contenuto principale
Sony Ericsson J22Oi Charging Port Replacement
Cosa ti serve
  1. Sony Ericsson J22Oi Charging Port Replacement, Battery: passo 1, immagine 1 di 1
    • Before disassembling the phone, make sure the phone is powered off.
  2. Sony Ericsson J22Oi Charging Port Replacement: passo 2, immagine 1 di 1
    • Flip to the back of the phone and locate the black button on the top of the phone.
  3. Sony Ericsson J22Oi Charging Port Replacement: passo 3, immagine 1 di 1
    • Firmly hold down the black button on the top of the phone and gently snap off the back cover.
  4. Sony Ericsson J22Oi Charging Port Replacement: passo 4, immagine 1 di 1
    • Remove the battery by wedging it out from the back.
  5. Sony Ericsson J22Oi Charging Port Replacement, Keypad: passo 5, immagine 1 di 1
    • Flip to the front of the phone and apply pressure to the front frame of the phone. The frame should snap off easily.
  6. Sony Ericsson J22Oi Charging Port Replacement: passo 6, immagine 1 di 1
    • Remove the keypad by gently pulling it from the front of the phone.
  7. Sony Ericsson J22Oi Charging Port Replacement, Screen: passo 7, immagine 1 di 1
    • Locate the five screws indicated on the phone.
  8. Sony Ericsson J22Oi Charging Port Replacement: passo 8, immagine 1 di 1
    • Use a T5 Screwdriver and unscrew the five screws.
  9. Sony Ericsson J22Oi Charging Port Replacement: passo 9, immagine 1 di 1
    • Once the screws are off, there should be a plastic cover on top of your screen. Gently slide the plastic cover off.
  10. Sony Ericsson J22Oi Charging Port Replacement: passo 10, immagine 1 di 1
    • Now gently pull metal cover off.
  11. Sony Ericsson J22Oi Charging Port Replacement: passo 11, immagine 1 di 1
    • You should now see the screen on the front side of the phone. Wedge your finger to the side of the phone. Apply some force to pop out the screen.
  12. Sony Ericsson J22Oi Charging Port Replacement: passo 12, immagine 1 di 1
    • Now that screen is removed, replace the old screen with the new screen.
    • Reassemble the device by doing the steps in reverse order.
  13. Sony Ericsson J22Oi Charging Port Replacement, Charging Port: passo 13, immagine 1 di 1
    • After removing the screen, you will find the charging port located at the bottom of the phone.
  14. Sony Ericsson J22Oi Charging Port Replacement: passo 14, immagine 1 di 1
    • Gently slide off the charging port.
Conclusione
James Au
Membro da: 10/06/12
10 Reputazione
4 Guide realizzate
Cal Poly, Team 6-36, Regan Fall 2012 Membro di Cal Poly, Team 6-36, Regan Fall 2012
CPSU-REGAN-F12S6G36
3 Membri
10 Guide realizzate
Un commento
Nice information for me , I also repairing the mobile phone
Mohit - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,368
