Salta al contenuto principale
Sony DVP-SR200P DVD Drive Replacement
Cosa ti serve
  1. Sony DVP-SR200P DVD Drive Replacement, Top Cover: passo 1, immagine 1 di 2 Sony DVP-SR200P DVD Drive Replacement, Top Cover: passo 1, immagine 2 di 2
    • Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
    • One 3/16" screw on the right side of the DVD player.
    • One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
    • Three 3/16" screws on the back of the DVD player.
  2. Sony DVP-SR200P DVD Drive Replacement: passo 2, immagine 1 di 2 Sony DVP-SR200P DVD Drive Replacement: passo 2, immagine 2 di 2
    • Slide the cover away from the front of the DVD player until it is off.
  3. Sony DVP-SR200P DVD Drive Replacement, Processing Board: passo 3, immagine 1 di 1
    • Remove the blue tape from the processing board by gently pulling upward.
  4. Sony DVP-SR200P DVD Drive Replacement: passo 4, immagine 1 di 2 Sony DVP-SR200P DVD Drive Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
    • The wires may be difficult to remove. Wiggling them while lifting them up may help remove them.
  5. Sony DVP-SR200P DVD Drive Replacement: passo 5, immagine 1 di 1
    • Handle the processing board with care. It is fragile.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
  6. Sony DVP-SR200P DVD Drive Replacement: passo 6, immagine 1 di 1
    • Orient the DVD player so that you are facing the video and audio jacks.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
    • The processing board is now free to be removed and replaced.
  7. Sony DVP-SR200P DVD Drive Replacement, DVD Drive: passo 7, immagine 1 di 1
    • Orient the DVD player so the front of the DVD player is opposite of you.
    • Remove the two #1 Phillips screws (silver, 3/16") that attach the DVD drive to the bottom of the DVD player.
  8. Sony DVP-SR200P DVD Drive Replacement: passo 8, immagine 1 di 1
    • Remove the DVD drive by pulling it backward and upward while ensuring that it is free of any braces.
Conclusione
Cal Poly, Team 5-17, Forte Winter 2013 Membro di Cal Poly, Team 5-17, Forte Winter 2013
CPSU-FORTE-W13S5G17
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 29
Tutti i Tempi: 3,648
