Salta al contenuto principale
Sony DVP-FX730 Screen Replacement
Cosa ti serve
  1. Sony DVP-FX730 Screen Replacement, Monitor: passo 1, immagine 1 di 2 Sony DVP-FX730 Screen Replacement, Monitor: passo 1, immagine 2 di 2
    • Use your hand to remove the small back cover by gently pulling upward.
  2. Sony DVP-FX730 Screen Replacement: passo 2, immagine 1 di 1
    • Using a screwdriver, remove the two 12 mm pan head screws.
  3. Sony DVP-FX730 Screen Replacement: passo 3, immagine 1 di 1
    • The screen should now detach from the primary device.
    • The wires, indicated with a blue box, will still connect the screen.
  4. Sony DVP-FX730 Screen Replacement: passo 4, immagine 1 di 2 Sony DVP-FX730 Screen Replacement: passo 4, immagine 2 di 2
    • Remove the wires attached to the white base using tweezers to pull them up.
  5. Sony DVP-FX730 Screen Replacement: passo 5, immagine 1 di 2 Sony DVP-FX730 Screen Replacement: passo 5, immagine 2 di 2
    • Referring back to Step 8, do the same with the wires attached to the black base.
  6. Sony DVP-FX730 Screen Replacement: passo 6, immagine 1 di 1
    • The screen should now be completely separated from the main device.
  7. Sony DVP-FX730 Screen Replacement, Screen: passo 7, immagine 1 di 1
    • Remove the four rubber feet and the screws beneath.
    • Remove the two exposed screws on the left side.
    • Pull back the cables until the screw is visible.
  8. Sony DVP-FX730 Screen Replacement: passo 8, immagine 1 di 1
    • Using the spudger, separate the top and bottom covers.
  9. Sony DVP-FX730 Screen Replacement: passo 9, immagine 1 di 1
    • Identify the gray back of the screen.
  10. Sony DVP-FX730 Screen Replacement: passo 10, immagine 1 di 1
    • Remove the screws.
  11. Sony DVP-FX730 Screen Replacement: passo 11, immagine 1 di 1
    • Remove the metal plates.
  12. Sony DVP-FX730 Screen Replacement: passo 12, immagine 1 di 2 Sony DVP-FX730 Screen Replacement: passo 12, immagine 2 di 2
    • Using spudger, push the lock clips to unlock the ribbon cable.
    • Using tweezers, pull the connector loose.
  13. Sony DVP-FX730 Screen Replacement: passo 13, immagine 1 di 2 Sony DVP-FX730 Screen Replacement: passo 13, immagine 2 di 2
    • Place your hand on the front of the screen and push upwards.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 11-21, Maness Winter 2012 Membro di Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 21
Tutti i Tempi: 2,699
