Introduzione
In order to access the internals of the device, the cover must be removed. If there is a problem with one of the components on the cover, it may need to be replaced.
Parti
Nessuna parte richiesta.
Remove the five exposed 7.9 mm phillips screws with the spudger.
  • Remove the five exposed 7.9 mm phillips screws with the spudger.
  • Punch through the warranty sticker with the spudger and remove the screw underneath.
Aggiungi Commento
Remove the rubber feet with the screwdriver.
  • Remove the rubber feet with the screwdriver.
  • Remove the screws that the rubber feet were covering.
Aggiungi Commento
Lift up the cover gently.
  • Lift up the cover gently.
  • The tray is still connected to the base with wires.
Aggiungi Commento
Remove the wires with tweezers by gently pulling on the base they are attached to.
  • Remove the wires with tweezers by gently pulling on the base they are attached to.
Aggiungi Commento
Conclusione
Rogelio Garcia
Membro da: 20/01/2012
10 Reputazione
1 Guida realizzata
Cal Poly, Team 11-21, Maness Winter 2012 Membro di Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,244
