Introduzione
Disassemble the camera to get to the lens.
Remove the battery. Unscrew the three screws that are circled. Repeat for circled screws on either side. These screws are all the same size. Remove the battery. Unscrew the three screws that are circled. Repeat for circled screws on either side. These screws are all the same size. Remove the battery. Unscrew the three screws that are circled. Repeat for circled screws on either side. These screws are all the same size.
  • Remove the battery. Unscrew the three screws that are circled. Repeat for circled screws on either side. These screws are all the same size.
Aggiungi Commento
Pull the frame around the LCD  up from the bottom of the camera and remove it. Pull the frame around the LCD  up from the bottom of the camera and remove it. Pull the frame around the LCD  up from the bottom of the camera and remove it.
  • Pull the frame around the LCD up from the bottom of the camera and remove it.
Aggiungi Commento
Gently push up the board from left corner. Gently push up the board only, not the whole metal assembly.
  • Gently push up the board from left corner.
  • Gently push up the board only, not the whole metal assembly.
  • Be gentle.
Aggiungi Commento
With needle nose pliers, gently bend back the metal tab at the bottom of the click wheel PCB so that you can release this board from the upper metal tab. Fold it away to the right and slide apart the ribbon cable from this board and place aside.
  • With needle nose pliers, gently bend back the metal tab at the bottom of the click wheel PCB so that you can release this board from the upper metal tab. Fold it away to the right and slide apart the ribbon cable from this board and place aside.
  • Then lift the LCD display away from the camera and again carefully remove two ribbon cables (boxed in blue) and place aside.
Aggiungi Commento
Remove the three screws circled in blue. Gently use a spudger to lever the metal assembly away from the camera body and place it aside.
  • Remove the three screws circled in blue. Gently use a spudger to lever the metal assembly away from the camera body and place it aside.
Aggiungi Commento
Insert wisdom here. Insert wisdom here.
  • Insert wisdom here.
Aggiungi Commento
Gently release the three flexible pcbs that are boxed in yellow. Now you can gently push the lens assembly from the front to clear it from the body. Gently release the three flexible pcbs that are boxed in yellow. Now you can gently push the lens assembly from the front to clear it from the body. Gently release the three flexible pcbs that are boxed in yellow. Now you can gently push the lens assembly from the front to clear it from the body.
  • Gently release the three flexible pcbs that are boxed in yellow. Now you can gently push the lens assembly from the front to clear it from the body.
Aggiungi Commento
The lens assembly is now removed from the body. The lens assembly is now removed from the body. The lens assembly is now removed from the body.
  • The lens assembly is now removed from the body.
Aggiungi Commento
Insert wisdom here.
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 27
Ultimi 30 Giorni: 82
Tutti i Tempi: 2,563
