Introduzione
Disassembling Sony Cybershot DSC-W5 in order to get to the battery terminal so that it can be replaced.
Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
  • Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
  • Remove both batteries.
Aggiungi Commento
Remove the single visible screw from both sides of the camera. Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
  • Remove the single visible screw from both sides of the camera.
  • Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
  • Do NOT remove all four screws from the bottom.
Aggiungi Commento
Gently remove the back cover from the camera. The first time the case is removed, it will be stiff. Be patient and gently rock the cover back and forth until it slides free.
  • Gently remove the back cover from the camera.
  • The first time the case is removed, it will be stiff. Be patient and gently rock the cover back and forth until it slides free.
Aggiungi Commento
Remove the two screws holding the circuit board down. Remove the two screws holding the circuit board down.
  • Remove the two screws holding the circuit board down.
Aggiungi Commento
Detach the orange cable from the board.
  • Detach the orange cable from the board.
  • Use a thin object, like a paperclip, to gently pry the cable off the connector.
Aggiungi Commento
The LCD screen sits in two slots; one on the bottom, and one on the left edge. Slide LCD screen from the two slots.
  • The LCD screen sits in two slots; one on the bottom, and one on the left edge.
  • Slide LCD screen from the two slots.
  • Do not attempt to completely remove the screen, as it is still attached to the camera.
Aggiungi Commento
To remove the LCD screen, detach the orange cable from the board. If needed, replace the LCD screen. If needed, replace the LCD screen.
  • To remove the LCD screen, detach the orange cable from the board.
  • If needed, replace the LCD screen.
Aggiungi Commento
Remove the two screws holding down the steel back plate. Remove steel back plate.
  • Remove the two screws holding down the steel back plate.
  • Remove steel back plate.
Aggiungi Commento
Now remove the plastic plate that covers the motherboard. Now remove the plastic plate that covers the motherboard.
  • Now remove the plastic plate that covers the motherboard.
Below and to the left of the viewfinder there is a vertical slot in the motherboard with a soldered connection to the flash capacitor on each side. Using a small screwdriver with an INSULATED handle, short these together for several seconds to discharge the potentially dangerous charge.
Philip Le Riche - Replica
Warning: Electric Shock From this point on, hold the camera by the chrome edges ONLY.  Capacitors store electric charge even if the batteries are removed. Remove the blue cable.
  • Warning: Electric Shock From this point on, hold the camera by the chrome edges ONLY. Capacitors store electric charge even if the batteries are removed.
  • Remove the blue cable.
Aggiungi Commento
Disconnect the flash cable (black and white wires) before completely removing the front case. Gently start to remove the case.
  • Disconnect the flash cable (black and white wires) before completely removing the front case.
  • Gently start to remove the case.
  • Once the cable is free, set aside the front case.
If the front doesn't seem to want to come away, maybe the flash cable is caught around its socket.
The speaker should now be clearly seen on the underside of the camera. Gently unplug the speaker from the motherboard.
  • The speaker should now be clearly seen on the underside of the camera.
  • Gently unplug the speaker from the motherboard.
  • Replace the speaker.
Aggiungi Commento
Remove the orange cable connecting the battery terminal to the motherboard. Remove the orange cable connecting the battery terminal to the motherboard.
  • Remove the orange cable connecting the battery terminal to the motherboard.
Aggiungi Commento
The battery terminal is now free from the board and can be slid out.
  • The battery terminal is now free from the board and can be slid out.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Thomas
Membro da: 14/04/2010
94 Reputazione
6 Guide realizzate
Cal Poly, Team 15-50, Garner Spring 2010 Membro di Cal Poly, Team 15-50, Garner Spring 2010
CPSU-GARNER-S10S15G50
5 Membri
6 Guide realizzate
Clean the little nobs in the pattery-pack and problem solved! I also removed the black plastic ring that was on the +pole inside.
martinenjellie - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 120
Tutti i Tempi: 12,165
