Parti
Nessuna parte richiesta.
Remove the battery Remove the five 2.5mm Philips #0 screws. Remove the one 2.5mm Philips #0 screw inside the HDMI case.
  • Remove the battery
  • Remove the five 2.5mm Philips #0 screws.
  • Remove the one 2.5mm Philips #0 screw inside the HDMI case.
Aggiungi Commento
Gently work and pull the front cover off of the camera
  • Gently work and pull the front cover off of the camera
Aggiungi Commento
Gently pull and disconnect the ribbon cable connecting the front cover to the main body
  • Gently pull and disconnect the ribbon cable connecting the front cover to the main body
Aggiungi Commento
  • Using an iSesamo Opening Tool, Spudger, or flat dull opening tool, gently pry off the cover of the OLED/LCD assembly.
    • Take care of the tab/clip at the bottom, it can be a little tricky.
    • iSesamo Opening Tool is highly recommended
Aggiungi Commento
Remove the copper phillips screw holding the HDMI mounting plate and detach the mounting plate. Remove the copper phillips screw holding the HDMI mounting plate and detach the mounting plate.
  • Remove the copper phillips screw holding the HDMI mounting plate and detach the mounting plate.
Aggiungi Commento
  • Using an iSesamo Opening Tool, Spudger, or flat dull opening tool, gently pry the OLED/LCD assembly from the adhesive strip on the main body.
    • Note: where the adhesive strip is located.
  • Turn the device over and remove the clear tape and black tape.
    • Important: Save the clear and black tape, they will be used for the replacement unit.
Aggiungi Commento
Gently pull the small flat ribbon cable from the main body
  • Gently pull the small flat ribbon cable from the main body
  • In order to disconnect the large flat ribbon cable, you need to flip up the black ribbon clamp located on the main body where the socket is located
Aggiungi Commento
Reattach new display, and reconnect all components
  • Reattach new display, and reconnect all components
  • Test camera to ensure the new screen is working
  • Congrats!
Aggiungi Commento
Conclusione
Tim
Membro da: 12/03/2012
1.392 Reputazione
2 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 3,508
