Introduzione
The sliding lens cover is on the front of the camera, and moves vertically to hide or expose the lens and flash. It may need to be replaced if it becomes stuck.
Parti
Nessuna parte richiesta.
Remove screws from outside of camera. There are 6 screws total. 3 screws on underside. 1 screw on right side, near battery cover.
  • Remove screws from outside of camera. There are 6 screws total.
  • 3 screws on underside.
  • 1 screw on right side, near battery cover.
  • 2 screws on left side.
Aggiungi Commento
Use screwdriver to remove screws.
  • Use screwdriver to remove screws.
Aggiungi Commento
Gently pull the front cover off of the main camera.
  • Gently pull the front cover off of the main camera.
  • All of the inner parts of the camera are attached to the back screen.
Aggiungi Commento
The front cover is now removed from the camera and the internal hardware is now exposed.
  • The front cover is now removed from the camera and the internal hardware is now exposed.
Aggiungi Commento
The front sliding lens cover.
  • The front sliding lens cover.
Aggiungi Commento
Remove four screws using Phillips located on the inside of the front cover. Remove four screws using Phillips located on the inside of the front cover.
  • Remove four screws using Phillips located on the inside of the front cover.
Aggiungi Commento
Remove front sliding lens cover. Remove front sliding lens cover.
  • Remove front sliding lens cover.
Aggiungi Commento
The front sliding lens cover is now removed and may be repair or replaced. The front sliding lens cover is now removed and may be repair or replaced.
  • The front sliding lens cover is now removed and may be repair or replaced.
Aggiungi Commento
Conclusione
Stephannie Allen
Membro da: 11/03/2013
189 Reputazione
10 Guide realizzate
Clemson, Team 13-1, Benson Spring 2013 Membro di Clemson, Team 13-1, Benson Spring 2013
CLEM-BENSON-S13S13G1
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 617
