Salta al contenuto principale
Sony Cyber-shot DSC-T9 Front Cover Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-T9 Front Cover Replacement, Battery: passo 1, immagine 1 di 1
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 Front Cover Replacement: passo 2, immagine 1 di 1
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 Front Cover Replacement, Front Cover: passo 3, immagine 1 di 3 Sony Cyber-shot DSC-T9 Front Cover Replacement, Front Cover: passo 3, immagine 2 di 3 Sony Cyber-shot DSC-T9 Front Cover Replacement, Front Cover: passo 3, immagine 3 di 3
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  4. Sony Cyber-shot DSC-T9 Front Cover Replacement: passo 4, immagine 1 di 1
    • Use screwdriver to remove screws.
  5. Sony Cyber-shot DSC-T9 Front Cover Replacement: passo 5, immagine 1 di 1
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  6. Sony Cyber-shot DSC-T9 Front Cover Replacement: passo 6, immagine 1 di 1
    • The front cover is now removed from the camera and the internal hardware is now exposed.
Conclusione
Clemson, Team 13-1, Benson Spring 2013 Membro di Clemson, Team 13-1, Benson Spring 2013
CLEM-BENSON-S13S13G1
4 Membri
20 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 17
Tutti i Tempi: 405
