Locate the cover on the bottom of the camera.
  • Locate the cover on the bottom of the camera.
  • Slide the cover towards the back of the camera.
  • Be careful—the battery can slide out on its own.
Aggiungi Commento
Carefully remove the exposed battery.
  • Carefully remove the exposed battery.
    • If it is difficult to remove, flip over the camera and the battery will slide out.
Aggiungi Commento
Locate and remove the 3mm screws on the top and sides of the camera with the size 00 screwdriver. Locate and remove the 3mm screws on the top and sides of the camera with the size 00 screwdriver. Locate and remove the 3mm screws on the top and sides of the camera with the size 00 screwdriver.
  • Locate and remove the 3mm screws on the top and sides of the camera with the size 00 screwdriver.
Aggiungi Commento
Pull the two halves of the camera apart.
  • Pull the two halves of the camera apart.
  • Place the two halves down with the insides facing you.
Aggiungi Commento
Find the two clips holding the motherboard to the black lens box.
  • Find the two clips holding the motherboard to the black lens box.
  • Slide the plastic opening tool in between the ribbon and the black part of the clip, then flip it. (If difficult, your fingernail can also be used)
Aggiungi Commento
After releasing the clips, pull out black lens box.
  • After releasing the clips, pull out black lens box.
Aggiungi Commento
Use the plastic opening tool to flip the clip. Use the plastic opening tool to flip the clip.
  • Use the plastic opening tool to flip the clip.
Aggiungi Commento
Grab the white part and slide it to the right until it clicks. This may require some force.
  • Grab the white part and slide it to the right until it clicks.
    • This may require some force.
  • Pull out the flash.
Aggiungi Commento
Use the plastic opening tool to release the clips.
  • Use the plastic opening tool to release the clips.
Aggiungi Commento
Flip the motherboard unit over. Flip the motherboard unit over.
  • Flip the motherboard unit over.
Aggiungi Commento
Pull the ribbon to separate the motherboard unit from the camera case. Pull the ribbon to separate the motherboard unit from the camera case.
  • Pull the ribbon to separate the motherboard unit from the camera case.
Aggiungi Commento
Use the #00 screwdriver to remove the 3mm screw located inside the white plastic piece.
  • Use the #00 screwdriver to remove the 3mm screw located inside the white plastic piece.
Aggiungi Commento
Remove the white plastic piece.
  • Remove the white plastic piece.
Aggiungi Commento
Use the #00 screwdriver to remove the 3mm screw.
  • Use the #00 screwdriver to remove the 3mm screw.
  • This is the back of the motherboard unit.
Aggiungi Commento
The only thing holding the motherboard in are stationary clips. Move the motherboard back and forth until it is loose and can be released from the motherboard unit.
  • The only thing holding the motherboard in are stationary clips.
  • Move the motherboard back and forth until it is loose and can be released from the motherboard unit.
Aggiungi Commento
You are left with the motherboard unit (on the left) and actual detached mother board (on the right).
  • You are left with the motherboard unit (on the left) and actual detached mother board (on the right).
Aggiungi Commento
Conclusione
Rosario
Membro da: 12/04/2012
24 Reputazione
3 Guide realizzate
Cal Poly, Team 7-35, Maness Spring 2012 Membro di Cal Poly, Team 7-35, Maness Spring 2012
CPSU-MANESS-S12S7G35
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 487
