Parti
Nessuna parte richiesta.
It is necessary to first locate the appropriate screws in order to disassemble the back casing. It is necessary to first locate the appropriate screws in order to disassemble the back casing. It is necessary to first locate the appropriate screws in order to disassemble the back casing.
  • It is necessary to first locate the appropriate screws in order to disassemble the back casing.
Aggiungi Commento
Remove the found screws with a small screwdriver.
  • Remove the found screws with a small screwdriver.
  • It is important to put the small screws in a safe location in order to reassemble the casing.
Aggiungi Commento
Carefully pull the back casing away from the camera.
  • Carefully pull the back casing away from the camera.
Aggiungi Commento
The back casing is now removed from the camera.
  • The back casing is now removed from the camera.
Aggiungi Commento
Conclusione
Katie McCraw
Membro da: 09/03/2012
191 Reputazione
7 Guide realizzate
Clemson, Team 1-5, Benson Spring 2012 Membro di Clemson, Team 1-5, Benson Spring 2012
CLEM-BENSON-S12S1G5
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,128
