Parti
Nessuna parte richiesta.
Unscrew the screws on the right side of the camera.
  • Unscrew the screws on the right side of the camera.
Aggiungi Commento
Using a plastic opening tool, lift and remove the silver piece on the right side of the camera. Using a plastic opening tool, lift and remove the silver piece on the right side of the camera.
  • Using a plastic opening tool, lift and remove the silver piece on the right side of the camera.
Aggiungi Commento
Use a plastic opening tool to push the tabs on each side of the front case forward. Remove the front case. Remove the front case.
  • Use a plastic opening tool to push the tabs on each side of the front case forward.
  • Remove the front case.
Aggiungi Commento
Lift and remove the silver piece on the left side of the camera with a plastic opening tool.
  • Lift and remove the silver piece on the left side of the camera with a plastic opening tool.
  • Unscrew the two screws on the left side of the camera.
Aggiungi Commento
Unscrew the three screws at the bottom of the camera.
  • Unscrew the three screws at the bottom of the camera.
Aggiungi Commento
Using a plastic opening tool, carefully separate and remove the back case. Using a plastic opening tool, carefully separate and remove the back case.
  • Using a plastic opening tool, carefully separate and remove the back case.
Aggiungi Commento
Conclusione
Dana Sanchez
Membro da: 21/10/2014
12 Reputazione
3 Guide realizzate
USF Tampa, Team 1-5, Leahy Fall 2014 Membro di USF Tampa, Team 1-5, Leahy Fall 2014
USFT-LEAHY-F14S1G5
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 200
